Discuss
Obsolete Thermadore Part Needed
 in
I am trying to locate an obsolete part: 20-09-115 (or could be 20-09-116). This is the front right burner for
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Obsolete Thermadore Part Needed
  #1 (permalink)
Old 04-11-2008, 10:15 AM
Junior Member
PaulH is on a distinguished road
Default Obsolete Thermadore Part Needed
Model Number: GCV36G   Brand: Thermador   Age: More than 10 years
I am trying to locate an obsolete part: 20-09-115 (or could be 20-09-116). This is the front right burner for the GCV36G cooktop.
The wife thought it was un-repairable and tossed in the garbage - so I can't repair it Kind of urgent as needed in order to close on the sale of our house. Any help would greatly be appreciated!!!
Ads By Google
Related Models
Thermador GCV36G
Whirlpool GD22DCXHB00
Whirlpool GD22DCXHB01
Whirlpool GD22DCXHB02
Whirlpool GD22DCXHS00
Whirlpool GD22DCXHS01
Whirlpool GD22DCXHS02
Whirlpool GD22DCXHT00
Whirlpool GD22DCXHT01
Whirlpool GD22DCXHT02
Whirlpool GD22DCXHW00
Whirlpool GD22DCXHW01
Whirlpool GD22DCXHW02
Whirlpool GD22DFXFB00
Whirlpool GD22DFXFB01
Whirlpool GD22DFXFB02
Whirlpool GD22DFXFB03
Whirlpool GD22DFXFB04
Whirlpool GD22DFXFN00
Whirlpool GD22DFXFN01
Whirlpool GD22DFXFN02
Whirlpool GD22DFXFN03
Whirlpool GD22DFXFN04
Whirlpool GD22DFXFT02
Whirlpool GD22DFXFT03
Whirlpool GD22DFXFT04
Whirlpool GD22DFXFW00
Whirlpool GD22DFXFW01
Whirlpool GD22DFXFW02
Whirlpool GD22DFXFW03
Whirlpool GD22DFXFW04
Whirlpool GD22DKXFW00
Whirlpool GD22DKXFW01
Whirlpool GD22DKXHW00
Whirlpool GD22DKXHW01
Whirlpool GD22DKXHW02
Whirlpool GD22DKXHW03
Whirlpool GD22DQXFB00
Whirlpool GD22DQXFN00
Whirlpool GD22DQXFW00
Whirlpool GD22SFXHS00
Whirlpool GD22SFXHS01
Whirlpool GD22SFXHS02
Whirlpool GD22SFXHS03
Whirlpool GD22SFXHS04
Whirlpool GD22SFXHS05
Whirlpool GD25BFCHB00
Whirlpool GD25BFCHB01
Whirlpool GD25BFCHT00
Whirlpool GD25BFCHT01
Whirlpool GD25BFCHW00
Whirlpool GD25BFCHW01
Whirlpool GD25DCXHS00
Whirlpool GD25DCXHS01
Whirlpool GD25DFXFB00
Whirlpool GD25DFXFB01
Whirlpool GD25DFXFB02
Whirlpool GD25DFXFB03
Whirlpool GD25DFXFN00
Whirlpool GD25DFXFN01
Whirlpool GD25DFXFN02
Whirlpool GD25DFXFN03
Whirlpool GD25DFXFT02
Whirlpool GD25DFXFT03
Whirlpool GD25DFXFW00
Whirlpool GD25DFXFW01
Whirlpool GD25DFXFW02
Whirlpool GD25DFXFW03
Whirlpool GD25DIXHB00
Whirlpool GD25DIXHB02
Whirlpool GD25DIXHS00
Whirlpool GD25DIXHS02
Whirlpool GD25DIXHT00
Whirlpool GD25DIXHT02
Whirlpool GD25DIXHW00
Whirlpool GD25DIXHW02
Whirlpool GD25DQXFB00
Whirlpool GD25DQXFB01
Whirlpool GD25DQXFN00
Whirlpool GD25DQXFN01
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
  #2 (permalink)
Old 04-11-2008, 09:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Paul,
I double checked for this part and it is no longer available.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-21-2008, 05:33 PM
Junior Member
andymh is on a distinguished road
Default Do you still have the cooktop?
I have that model. I need 3 out of 4 burner knob assemblies (the switches, not the knobs). Or I might get rid of it. If you still have yours, maybe one of us can salvage the cooktop.
  #4 (permalink)
Old 08-04-2008, 06:58 AM
Junior Member
ChrisLadd is on a distinguished road
Default Need the same switch
The switch for the right rear burner on my Thermador GCV36G stove top won't turn anymore. The part is listed as number 16. Anyone still have one of those?
  #5 (permalink)
Old 08-04-2008, 07:40 AM
Junior Member
Default a fix which worked for me
Quote:
I had this problem on 3 of 4 of my burners, and it turned out that on all 3, it was corrosion on the valve cylinder. I was able to break the corrosion on 2 of the 3 and restore them without replacing any parts. The one unsuccessful attempt was my first where I tried to break the corrosion with the dial. Don't do this. I only managed to break the metal locking tab, which rendered that dial completely useless. Here's what to do:
  • First, turn off the gas to your stove. (It is very easy to pull out the valve cylinder and permit gas to flow at high volume into your kitchen.)
  • Remove the dials and raise the stove top to expose the valves.
  • Remove the screws holding on the black starter switch (I'm telling you this from memory -- so there may be one or two steps I'm forgetting -- but they should be obvious.) For example, you may have to remove the electrical leads to the starter switch.
  • Remove the spring that covers the solid valve cylinder.
  • With a pair of pliers, carefully grip the top of the cylinder, and with some bit of force, turn the cylinder back and forth until it turns easily. I did not apply WD40 or graphite lubricant as I wasn't certain this was advisable, and simply breaking the corrosion was sufficient.
  • Reassemble the valve. I found that a flathead screwdriver was helpful in holding down the spring while replacing the starter switch.
  • Test that the dial now can turn and that the starter also sparks.
  • Turn on the gas and be certain none is leaking.
Hope this works for you. Let me know.
  #6 (permalink)
Old 08-04-2008, 09:36 AM
Junior Member
Default
Unbelievable. It was only one burner. It was gas, so I wasn't going to mess with it if I couldn't just buy a new valve. But for you it was three valves. And necessity is the mother of invention. Thanks ten times over.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace Oven Gasket for obsolete part stoveandi Oven Repair (including Ranges and Cooktops) 0 12-02-2009 05:03 PM
Substitute for Obsolete Oven Door Part-Help Please egarts Oven Repair (including Ranges and Cooktops) 0 11-07-2009 05:09 PM
unavailable part needed jobyx2 Dryer Repair 0 10-26-2009 09:14 AM
replacement part needed Teresa Habern General Talk 0 02-13-2009 08:55 AM
what part is needed paul kon Washer Repair 1 07-09-2008 03:49 AM
