Discuss
Whirlpool Range - DSI Unit Not detecting Flame
 in
I have read through the DSI troubleshoot manual for this range and it appears as though the flame detection device
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Range - DSI Unit Not detecting Flame
  #1 (permalink)
Old 08-24-2007, 10:36 AM
jdog4 jdog4 is offline
Junior Member
jdog4 is on a distinguished road
Default Whirlpool Range - DSI Unit Not detecting Flame
Model Number: SF357PEKT1   Brand: Whirlpool   Age: 5 - 10 years
I have read through the DSI troubleshoot manual for this range and it appears as though the flame detection device is not working correctly. When I set my oven to Bake or Broil, the igniter kicks on and lights the gas. The ignitor keeps going and after 4 seconds the gas turns off. This will occur 3 times within the 3 minutes and then the oven will kick into lock down mode for a while.
I have checked the voltage on the DSI and all appears correct per the instructions, so the last three options are to, 1 Check ignitor for continuity, (not sure what this means?), Check polarity - circuits are wired correctly, and ignitors work - so this would appear to be OK, and lastly - replace the DSI. I have no problem replacing the part, but I want to be sure that this is the problem, given that everything else appears to work correctly.
Could it be an earth problem as well - I have checked for loose wires and connections but cant isolate any particular problem??
Any suggestions would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Unit tripping breaker tadtv Refrigerator & Freezer Repair 0 08-13-2007 06:05 PM
ac window unit trae southard Heating, Ventilation, and Air Conditioning (HVAC) 0 08-10-2007 02:33 PM
Only 1 fan speed / Unit turns itself off KenK Heating, Ventilation, and Air Conditioning (HVAC) 0 08-09-2007 09:25 AM
Igniter glows but no flame. zab Dryer Repair 1 08-06-2007 07:55 PM
oven/broiler control unit dynaguy Oven Repair (including Ranges and Cooktops) 1 07-31-2007 05:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
