The oven element can heat to over 500 degrees but does not hold a set temp. The broiler element gets warm but not hot. The fan runs all the time. I replaced the snap thernostat and the oven sensor with no improvement. My next step seems to be to replace the oven control board or the relay board. I can't find the oven control board at AppliancePartsPro. The relay board is over $100 so I wouldn't want to order it unnecessarily. Advice Please.
