| » Thermador BBQ |
Model Number: CGBD36RX Brand: Thermador Age: 5 - 10 years
Thermador BBQ CGBD36RX
The infrared burner starter is broken. The shield covers the screw and I don't see how to get at the part. Please, how do you get at it for the repair. Thanks. Doug The Ignitor, Hot Surface (AP2836885) seems to be what I need for the repair. Ads By Google Related Models Last edited by MoliMan : 01-23-2010 at 02:45 AM. |
Thanks. I did find how to remove it from the back side. The fit of this unit is poor. One of the screws cannot be removed because the spot welded flange is offset. Thermador ain't what it used to be ....
Got the new part and then dropped it putting the hex extensions on. Brittle little critter. Another $90 learning experience. Thanks again for the help. |
I am working on a unit that has the position of the front panel and the bullnose reversed. The panel is outside the bullnose, so I cannot get to the screws that hold the bullnose in place. I can only remove the panel's bottom screws, which leaves it tightly wedged in to the bullnose at the panel's top edge. How can this be removed?
Hello, I believe one of the screws which hold the knob bezel also helps to secure the control panel onto the front of the unit. Refer to page 11 of the service manual that's attached to the above post for control panel removal instructions. KC |
| Display Modes | |
| thermador MCM 255 - | roxy | Oven Repair (including Ranges and Cooktops) | 6 | 11-26-2010 08:41 AM |
| Thermador | gy58 | Oven Repair (including Ranges and Cooktops) | 1 | 06-17-2009 07:31 AM |
| Thermador | IVANWEINSTEIN | Oven Repair (including Ranges and Cooktops) | 0 | 04-22-2009 07:41 AM |
| Thermador Help | gearhead1218 | Oven Repair (including Ranges and Cooktops) | 6 | 04-11-2008 08:21 PM |
| thermador | vsabl | Oven Repair (including Ranges and Cooktops) | 2 | 03-27-2008 06:25 AM |
