| » Replacing the electrode of the spark igniter |
Model Number: JGBP79WEA1WW Brand: GE Age: 1 - 5 years
Hello,
2 of the 4 spark igniters on my stove top have stopped working consistently. When I turn the knob to the "iite" position, it doesn't spark like the other burners that work. Some times it works, but most of the time it doesn't. I called GE and they said that I can order a replacement electrode and replace it myself; however, they won't be sending instructions with the parts. Is this an easy part to replace by myself? I pulled out the electrode and it was attached to a wire. Any advice would be much appreciated. Thanks. Last edited by DJH : 04-10-2008 at 03:15 PM. |
If you already pulled out the electrode - you went more then half way. The wire just plugs into the electrode. Pull it out and plug into the new electrode.
But... The first thing I would check is the ceramic part of the ignition electrode. If it's not broken and not cracked - it's fine. If there is nothing wrong with the ceramic insulation then the problem is a bad spark module (located inside the control panel). - The part number for the ignition electrode is AP2020574 - The part number for the spark module is AP2020570 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Yes, this part is not too difficult to replace yourself. Remove the rear cover from the control panel and you'll see it.
__________________
I'm glad you were able to fix it.
__________________
| Display Modes | |
| GE gas cooktop igniter won't spark and lit | ewe | Oven Repair (including Ranges and Cooktops) | 1 | 03-04-2008 04:43 PM |
| GE gas cooktop igniter won't spark and lit | ewe | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2008 11:34 PM |
| Whirlpool Oven Spark Electrode Install | mattsegawa | Oven Repair (including Ranges and Cooktops) | 2 | 11-19-2007 01:45 PM |
| Spark Igniter | pgronvall | Oven Repair (including Ranges and Cooktops) | 0 | 11-08-2007 06:55 AM |
| spark igniter substitution | Meterman | Oven Repair (including Ranges and Cooktops) | 5 | 10-20-2007 03:01 PM |
