Discuss
Jen Air JEC 9530 ADB Burner replacement
 in
I purchased a replacement burner , front right dual burner, form you and it was delivered . ( part #
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jen Air JEC 9530 ADB Burner replacement
  #1 (permalink)
Old 01-20-2010, 10:15 AM
Junior Member
Bill Gordon is on a distinguished road
Default Jen Air JEC 9530 ADB Burner replacement
Model Number: JEC 9530 ADB   Brand: Jenn-Air   Age: 5 - 10 years
I purchased a replacement burner , front right dual burner, form you and it was delivered . ( part # WPL 74008228 )I went to install last night and noticed there was a slight difference in wiring.On the old burner ther are 3 connections on the burner, a gery line, a white , and a yellow line. The grey line went from a box( the limiter?) to the center tab on the burner. The new part has a direct connection... no wire used from the tab on the limiter (?) to the burner. I now have two tabs left for the yellow and white wires. there is a red dot above one of the remainng open tabs and I am assuming the grey wire is relaced by the direct connect. The question is... do I have the right part? and if so which tab does the yellow go to and which the white?? I have it all apart and would like to get it reinstalled tonight so a quick answer would be appreciated. Thank You very much. Bill Gordon
Ads By Google
Related Models
Jenn-Air JEC0530ADB Surface Unit - Ele
Jenn-Air JEC0530ADS Surface Unit - Ele
Jenn-Air JEC0530ADW Surface Unit - Ele
Jenn-Air JEC0536ADB Surface Unit - Ele
Jenn-Air JEC0536ADS Surface Unit - Ele
Jenn-Air JEC0536ADW Surface Unit - Ele
Jenn-Air JEC7430AAB Surface Unit - Ele
Jenn-Air JEC7430AAW Surface Unit - Ele
Jenn-Air JEC8430ADB Surface Unit - Ele
Jenn-Air JEC8430ADF Surface Unit - Ele
Jenn-Air JEC8430ADN Surface Unit - Ele
Jenn-Air JEC8430ADS Surface Unit - Ele
Jenn-Air JEC8430ADW Surface Unit - Ele
Jenn-Air JEC8536ADB Surface Unit - Ele
Jenn-Air JEC8536ADF Surface Unit - Ele
Jenn-Air JEC8536ADN Surface Unit - Ele
Jenn-Air JEC8536ADS Surface Unit - Ele
Jenn-Air JEC8536ADW Surface Unit - Ele
Jenn-Air JEC9530ADB Surface Unit - Ele
Jenn-Air JEC9530ADF Surface Unit - Ele
Jenn-Air JEC9530ADS Surface Unit - Ele
Jenn-Air JEC9530ADW Surface Unit - Ele
Jenn-Air JEC9530BDB Surface Unit - Ele
Jenn-Air JEC9530BDF Surface Unit - Ele
Jenn-Air JEC9530BDR Surface Unit - Ele
Jenn-Air JEC9530BDS Surface Unit - Ele
Jenn-Air JEC9536ADB Surface Unit - Ele
Jenn-Air JEC9536ADF Surface Unit - Ele
Jenn-Air JEC9536ADS Surface Unit - Ele
Jenn-Air JEC9536ADW Surface Unit - Ele
Jenn-Air JEC9536BDB Surface Unit - Ele
Jenn-Air JEC9536BDF Surface Unit - Ele
Jenn-Air JEC9536BDS Surface Unit - Ele
Jenn-Air JED7430AAB Electric Grill Outdoor
Jenn-Air JED8130ADB Surface Unit - Ddraft Ele
Jenn-Air JED8130ADW Surface Unit - Ddraft Ele
Jenn-Air JED8230ADB Surface Unit - Ddraft Ele
Jenn-Air JED8230ADS Surface Unit - Ddraft Ele
Jenn-Air JED8230ADW Surface Unit - Ddraft Ele
Jenn-Air JED8345ADB Surface Unit - Ddraft Ele
Jenn-Air JED8345ADW Surface Unit - Ddraft Ele
Jenn-Air JED8430ADB Surface Unit - Ddraft Ele
Jenn-Air JED8430ADQ Surface Unit - Ddraft Ele
Jenn-Air JED8430ADW Surface Unit - Ddraft Ele
Jenn-Air JED8430BDB Surface Unit - Ddraft Ele
Jenn-Air JED8430BDF Surface Unit - Ddraft Ele
Jenn-Air JED8430BDN Surface Unit - Ddraft Ele
Jenn-Air JED8430BDS Surface Unit - Ddraft Ele
Maytag JEI0430ADS0 30" Inducton Cooktop
Maytag JEI0536ADS0 36" Induction Cooktop
General Electric JEI83101 Counter top microwave
General Electric JEI832WN01 Counter top microwave
General Electric JEM10001 Counter top microwave
General Electric JEM10E01 Counter top microwave
General Electric JEM10F01 Counter top microwave
General Electric JEM10G01 Counter top microwave
General Electric JEM18F01 Counter top microwave
General Electric JEM2-001
General Electric JEM20001 Counter top microwave
General Electric JEM20E01 Counter top microwave
General Electric JEM20F01 Counter top microwave
General Electric JEM20G01 Counter top microwave
General Electric JEM20H01 Counter top microwave
General Electric JEM20H02 Counter top microwave
General Electric JEM21001 Counter top microwave
General Electric JEM21E01 Counter top microwave
General Electric JEM21K01 Counter top microwave
General Electric JEM21K02 Counter top microwave
General Electric JEM21K03 Counter top microwave
General Electric JEM21K04 Counter top microwave
General Electric JEM21L01 Counter top microwave
General Electric JEM21L02 Counter top microwave
General Electric JEM22E01 Counter top microwave
General Electric JEM22H01 Counter top microwave
General Electric JEM23E01 Counter top microwave
General Electric JEM23F01 Counter top microwave
General Electric JEM23G01 Counter top microwave
General Electric JEM23K01 Counter top microwave
General Electric JEM23K02 Counter top microwave
General Electric JEM23K03 Counter top microwave
General Electric JEM23K04 Counter top microwave
General Electric JEM23L01 Counter top microwave
General Electric JEM23L02 Counter top microwave
General Electric JEM25BF001 Counter top microwave
General Electric JEM25BF01 Counter top microwave
General Electric JEM25BF02 Counter top microwave
General Electric JEM25GV01 Counter top microwave
General Electric JEM25GV02 Counter top microwave
General Electric JEM25GV03 Counter top microwave
General Electric JEM25GY01 Counter top microwave
General Electric JEM25J01 Counter top microwave
General Electric JEM25L01 Counter top microwave
General Electric JEM25WF001 Counter top microwave
General Electric JEM25WF01 Counter top microwave
General Electric JEM25WF02 Counter top microwave
General Electric JEM25WV01 Counter top microwave
General Electric JEM25WV02 Counter top microwave
General Electric JEM25WV03 Counter top microwave
General Electric JEM25WY01 Counter top microwave
General Electric JEM26WH01 Counter top microwave
General Electric JEM27KWH01 Counter top microwave
General Electric JEM27KWH02 Counter top microwave
General Electric JEM27KWH03 Counter top microwave
General Electric JEM27KWH04 Counter top microwave
General Electric JEM27LWH01 Counter top microwave
General Electric JEM27LWH02 Counter top microwave
General Electric JEM2F01 Counter top microwave
General Electric JEM2G01 Counter top microwave
General Electric JEM2H01 Counter top microwave
General Electric JEM3-001
General Electric JEM30WH01 Counter top microwave
General Electric JEM31BF001 Counter top microwave
General Electric JEM31BF01 Counter top microwave
General Electric JEM31BF02 Counter top microwave
General Electric JEM31CA001 Counter top microwave
General Electric JEM31CF001 Counter top microwave
General Electric JEM31CF01 Counter top microwave
General Electric JEM31CF02 Counter top microwave
General Electric JEM31E01 Counter top microwave
General Electric JEM31F01 Counter top microwave
  #2 (permalink)
Old 01-20-2010, 07:21 PM
Junior Member
Default
I was helped on the phone and figured out the wiring, however when I hooked it all up and plugged it in I still have the same problem. Looks like it was not the burner after all. When cold and I turn on the burner the center , smaller will get hot. In 45 seconds it shuts down. The outer, larger burner never goes on. The fan runs, the indicator light goes on but the burner does not heat. 2 questions: can I return the burner since my old one seems to be fine and what part do I need to fix it? The switch? It seems to be the only other thing as a new limiter was included on the burner. I checked all the wires and all seemed tight and there were no breaks or fraying of insulation. I wiggled all the connections and all seemed good. Help! Thank you . Bill G
  #3 (permalink)
Old 01-21-2010, 02:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bill,
Have you connected the sensor plug from the heating element to the surface control board?
If yes, then check the control board as described in the Tech sheet.
Here is the Service manual.
- The custom control kit Part number: AP4009645
Here are the breakdown diagrams and Replacement parts for JENN-AIR JEC9530ADB Surface Unit - Ele | AppliancePartsPros.com
P.S. All customer service related issues should be addressed to the customer service. We work on the forum as a volunteers to help people with technical problems.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 01-21-2010, 03:21 PM
Junior Member
Default Thank you for responding
I have connected all the wires to the new burner in the same fasion as they were connected to the old one. The problem I experienced with the old unit persists with the new one. Exact same peformance. The center goes on for 20 seconds and then shuts off. The outer burner never goes on. The indicator lights illuminate and the fan goes on the center heats up and 20 seconds later it goes out. It won't go on again until the unit cools. Since the problem is the same with the new burner I guess the problem is with the switch the $125 part ...the custom controll kit.. or the wiring in between which I inspected and it looked fine. Should I just order the controll unit and R&R? Thank you for your help. BG
  #5 (permalink)
Old 01-21-2010, 11:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bill,
You already ordered one part without proper diagnosis. Guessing is one of the most expensive way to fix appliances.
__________________
  #6 (permalink)
Old 01-22-2010, 08:56 AM
Junior Member
Default Ouch
that was not particularly helpful however I get your point. Unfortunately I am not as experienced with a multi meter as I should be and will likely will not be capable of performing the proper diagnosis. The way the diagram of the unit appears there are ony a couple of options that could cause this problem. 1.. the burner... well thats not it.. 2. the switch - which by the way makes a static noise when the burner has heated and then turned off, when you move the switch there is a static sound as the burner tries to come on or 3. the wiring between the two which appears fine and all connections are good. I will break out a multi meter this weekend and try. If you have any suggestions I would be very greatful. Thank you .
  #7 (permalink)
Old 01-22-2010, 03:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bill,
I agree, in such situation there is a big chance for the custom control to be bad, but it is better to confirm it (if it's possible) before you spend $140.
__________________
  #8 (permalink)
Old 05-15-2012, 08:45 AM
Junior Member
nonenone is on a distinguished road
Default 16026558 Techsheet
Quote:
Originally Posted by Gene View Post
Bill,
Does anyone have a new link to the Tech sheet 16026558 referenced above? The provided link is dead.
  #9 (permalink)
Old 05-15-2012, 06:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The Tech sheet is attached.
__________________
  #10 (permalink)
Old 05-15-2012, 09:19 PM
Junior Member
Default
Thank you for the new link
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Burner Valve Replacement mrcaleggs Oven Repair (including Ranges and Cooktops) 0 11-22-2009 10:29 PM
burner replacement kcnbear Oven Repair (including Ranges and Cooktops) 0 09-19-2009 02:31 PM
burner replacement jamie1234 Oven Repair (including Ranges and Cooktops) 2 09-07-2009 02:22 PM
sealed burner replacement wanabe Oven Repair (including Ranges and Cooktops) 0 01-25-2009 01:02 PM
