replaced broiler ignitor and still not glowing. no power getting to it also it will not go let me set the self clean mode properly. i lock door push clean set temp on high both lock and clean lights blink and stay on but it does not lock door or get hot enough
Locate the broiler part on the gas safety valve (#4 on the diagram). Remove the wires from the two terminals and check for continuity across these terminals. If there is no continuity, replace the gas safety valve. If there is continuity, replace the control board. - The gas safety valve assembly Part number: AP4008707
