Discuss
oven thermostat not correct
 in
for the past few weeks the oven will indicate that it is preheated with a beep and the indicater light,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven thermostat not correct
  #1 (permalink)
Old 01-19-2010, 08:04 PM
Junior Member
craigt6627 is on a distinguished road
Default oven thermostat not correct
Model Number: ARG7302CC   Brand: Amana   Age: 5 - 10 years
for the past few weeks the oven will indicate that it is preheated with a beep and the indicater light, but a thermometer in the oven will show the temp way below (if set at 350 it may get to 275 when preheat indicator lights). To get the temperature to the needed temp I have to set it at least 50 degrees above the needed temperature. I set the temp to 350 and removed the shield so I could see the burner and the burner turned off at about 275. so it seems to be a sensor issue. but i am wondering if it could be something else
Ads By Google
Related Models
Amana ARG7302CC Range - S/c S/i Ddraft Gas
Amana ARG7302LL Range - S/c S/i Ddraft Gas
Amana ARG7302WW Range - S/c S/i Ddraft Gas
Amana ARG7303CC Range - S/c F/s Gas
Amana ARG7303LL Range - S/c F/s Gas
Amana ARG7303WW Range - S/c F/s Gas
Amana ARG7600CC Range - S/c S/i Ddraft Gas
Amana ARG7600L Range - S/c F/s Gas
Amana ARG7600LL Range - S/c S/i Ddraft Gas
Amana ARG7600W Range - S/c S/i Ddraft Gas
Amana ARG7600WW Range - S/c S/i Ddraft Gas
Amana ARG7800CC Range - S/c S/i Ddraft Gas
Amana ARG7800E Range - S/c S/i Ddraft Gas
Amana ARG7800LL Range - S/c S/i Ddraft Gas
Amana ARG7800SS Range - S/c S/i Ddraft Gas
Amana ARG7800WW Range - S/c S/i Ddraft Gas
Amana ARGS7650CC Range - S/c S/i Ddraft Gas
Amana ARGS7650E Range - S/c S/i Ddraft Gas
Amana ARGS7650LL Range - S/c S/i Gas
Amana ARGS7650SS Range - S/c S/i Gas
Amana ARGS7650WW Range - S/c S/i Gas
  #2 (permalink)
Old 01-20-2010, 04:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for AMANA ARG7302CC Range - S/c S/i Ddraft Gas | AppliancePartsPros.com
Yes it could be something else ( a bad board etc.) but at the top of the list is the sensor. Check it with a meter.
Below is a good site with info.
http://www.applianceaid.com/elecrange.html
Check out 7, 8, 20 1nd 21.
Note: That the temp sensor is a positive device (resistance rises with temperature) so if you have a poor/loose/dirty connection the unit will interpret this as a higher than actual oven temperature.
Check all connections to the sensor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven temp not correct jeg13 Oven Repair (including Ranges and Cooktops) 0 04-01-2009 12:11 PM
Oven not baking at correct temp Tracylsmith Oven Repair (including Ranges and Cooktops) 3 03-14-2009 01:44 PM
Oven Thermostat Knob won't align with correct temperature jmellis80 Oven Repair (including Ranges and Cooktops) 0 02-14-2009 10:56 AM
oven not holding correct temp aubbie Oven Repair (including Ranges and Cooktops) 3 12-11-2008 09:53 AM
Oven won't reach correct heat AnnH Oven Repair (including Ranges and Cooktops) 3 01-16-2008 03:55 PM
