Discuss
Thermador Help
 in
I just found this forum and decided to join. Boy I just don't like Thermadors. I'm working on an RDDS30VRS.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Help
  #1 (permalink)
Old 04-07-2008, 05:32 PM
Member
gearhead1218 is on a distinguished road
Default Thermador Help
Model Number: RDdS30VRS   Brand: Thermador   Age: 5 - 10 years
Clock won't power up the oven or broiler. I did the obvious thing and
ordered a replacement clock and installed it.
New clock installed, doing the same thing, but now giving me an F1
alert. F1 is stated as an ERC (clock) board failure.
I've also noticed that the broil element is blown out.
I'm going to be ordering another clock an a broil element.
My brain frazzler is that I'm hearing a "clicking" noise from the back
of the oven as I try to fire up the oven or broiler with the current
clock. I hit the bake or broil button, It won't allow me to select a
temp. OFF is displayed and I hear the click. OFF goes off, clicks again.
My real blurry wiring diagram shows no relays back there that I can
decipher. Another oven that was a similar model I looked at didn't
appear to have any relays back there. This oven is a slide-in that was
tiled in front of it, so it will need to be lifted 4 to 6 inches then
slid out on to a platform that I'm going to make to not destroy this
tile work. All to look at the back of the oven. Oh yeah, and there's
that retracting exhaust fan to remove before pulling the back off the
range.
So, are there or aren't there relays back there????????
Or am I just hearing things???
Ads By Google
Related Models
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Whirlpool RDE1100W0
Whirlpool RDE1100W1
Whirlpool RDE1100W2
Whirlpool RDE1300W
Whirlpool RDE1300W1
Whirlpool RDE1300W2
Whirlpool RDE1400W
Whirlpool RDE1400W1
Whirlpool RDE1400W2
Whirlpool RDE22302
Whirlpool RDE2300W
Whirlpool RDE2300W1
Whirlpool RDE2300W2
Whirlpool RDE2400P0
Whirlpool RDE2400P1
Whirlpool RDE2400P2
Whirlpool RDE2400W0
Whirlpool RDE2400W1
Whirlpool RDE2400W2
Whirlpool RDE2500P0
Whirlpool RDE2500P1
Whirlpool RDE2500P2
Whirlpool RDE3000W
Whirlpool RDE3020W
Whirlpool RDE3100W
Whirlpool RDE31E0W
Whirlpool RDE32302
Whirlpool RDE3230W
Whirlpool RDE3300W
Whirlpool RDE3340W
Whirlpool RDE3360W
Whirlpool RDE3400W
Whirlpool RDE3400W1
Whirlpool RDE3400W2
Whirlpool RDE3450W
Whirlpool RDE34EPW
Whirlpool RDE350PW
Whirlpool RDE350PW1
Whirlpool RDE355PP
Whirlpool RDE3600W
Whirlpool RDE3600W2
Whirlpool RDE3700W
Whirlpool RDE3700W1
Whirlpool RDE3700W2
Whirlpool RDE3900W
Whirlpool RDE3900W1
Whirlpool RDE390PW
Whirlpool RDE390PW2
Whirlpool RDE3950W
Whirlpool RDE395PP
Whirlpool RDE4400W0
Whirlpool RDE4400W1
Whirlpool RDE4400W2
Whirlpool RDE4900W
Whirlpool RDE4900W1
Whirlpool RDE4900W2
Whirlpool RDE4950W
Whirlpool RDE6030W0
Whirlpool RDE6030W1
Whirlpool RDE6030W2
Whirlpool RDE6030W3
Whirlpool RDE6100W
Whirlpool RDE6100W1
Whirlpool RDE6100W2
Whirlpool RDE6300W
Whirlpool RDE6300W1
Whirlpool RDE6300W2
Whirlpool RDE630PN0
Whirlpool RDE6550W
Whirlpool RDE6550W1
Whirlpool RDE6550W2
Whirlpool RDE6700W
Whirlpool RDE6700W1
Whirlpool RDE6700W2
Whirlpool RDE8400W
Whirlpool RDE8400W1
Whirlpool RDE8400W2
Whirlpool RDE8500W
Whirlpool RDE8500W1
Whirlpool RDE8500W2
Whirlpool RDE8550
Whirlpool RDE85501
Whirlpool RDE85502
Whirlpool RDE950PW
Whirlpool RDE950PW1
Whirlpool RDE950PW2
Whirlpool RDE955PP
Whirlpool RDE9600W
Whirlpool RDE9600W2
Thermador RDF30
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Whirlpool RDH2030
Whirlpool RDH2036
Whirlpool RDH2330
Whirlpool RDH2336
Whirlpool RDH2630
Whirlpool RDH2636
Whirlpool RDH4330
Whirlpool RDH4336
Whirlpool RDH4630
Whirlpool RDH4636
Whirlpool RDH7330
Whirlpool RDH7336
Whirlpool RDH7630
Whirlpool RDH7636
Whirlpool RDH8330
Whirlpool RDH8630
Whirlpool RDH9330
Whirlpool RDH9630
Jenn-Air RDK100W Misc / Accessory
  #2 (permalink)
Old 04-08-2008, 03:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm not familiar with this model but most of Thermador ovens have a thermal cut-off on the back of the oven or on the top (behind the control panel) and usually they are resettable.
Also I believe the "F1" error code means a problem with the touch pad and not with the control board.
Here are the break down diagrams for the Thermador range Model RDDS30VRS S/N 9707 & UP
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-08-2008, 04:32 PM
Member
Default
F1 is ERC (clock) failure. Which is the part I replaced. Touch Pad and clock are one in the same.
I did see two small klixon limits in the same area as the clock. They don't seem to be an issue.
When I hit the bake or broil buttons to try and heat the oven, "OFF" is displayed and the ERC will not allow me to adjust the temps. Then about 5 seconds or so after the "OFF" goes out. When "OFF" goes on and off I hear a click from what sounds to be behind the oven. If there's any relays back there then I'll need to pull the oven. Which will be VERY ugly. And this unit has the retracting downdraft fan that will have to be removed to get to the back.
Oh yeah, just TRY and print out that wiring diagram. It won't come out at all legibly.
  #4 (permalink)
Old 04-08-2008, 07:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
According to the Thermador tech sheets the causes of the "F1" error code could be a stuck button or a stuck latch switch and the last one - the ERC.
Check all buttons, especially the "Cancel". You've got this error code after you replaced the ERC and very possible one of the buttons got stuck during the installation of the new clock.
There is the High Temperature Cutout switch for the Bake and the Broil heating elements which is located in the right side panel and is resettable.
If this switch is open it'll interrupt power to both heating elements.
Hopefully you would not have to remove the range to access the HTC switch.
Remove the control panel end caps and the glass from the range.
Remove the two screws from the right front cover, slide the cover forward to unlock it and remove it from the range.
Remove the four screws from the right rear cover and remove the cover.
Press the red reset button in the center of the HTC switch.
__________________
  #5 (permalink)
Old 04-09-2008, 05:38 PM
Member
Default
Thanks Gene.
When I go back to the customer, I'll check for that limit switch.
Any thoughts on if there are any relays or switches in the back of the oven????
  #6 (permalink)
Old 04-11-2008, 06:11 PM
Member
Default
Well, I made it back to this customer's house today. I brought help to pull the oven and some lumber to build a platform in order to pull this piece of you know what.
I replaced the new clock I previously installed, and put in a new broil element. It took off and ran perfectly. I didn't have to pull it. Boy what a relief, this thing was giving me nightmares.
Glen, I was able to see the hi-limit on the right side buried behind that side cover. I would have had to pull that oven to remove the side cover. That is a piss-poor design.
  #7 (permalink)
Old 04-11-2008, 08:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador BBQ MoliMan Oven Repair (including Ranges and Cooktops) 4 03-10-2011 04:37 AM
thermador MCM 255 - roxy Oven Repair (including Ranges and Cooktops) 6 11-26-2010 08:41 AM
Thermador gy58 Oven Repair (including Ranges and Cooktops) 1 06-17-2009 07:31 AM
Thermador IVANWEINSTEIN Oven Repair (including Ranges and Cooktops) 0 04-22-2009 07:41 AM
thermador vsabl Oven Repair (including Ranges and Cooktops) 2 03-27-2008 06:25 AM
