| » elements not heating |
Model Number: RF377pxg Brand: Whirlpool Age: 5 - 10 years
all elements not heating up there is power all the LED's work the clock works, the timer works the oven clean switches work I had a PF power failure signal is there a reset tehcnique or maybe the thermostat any ideas will help thanks
Looks like you are missing a couple digits off the end of your model number.
If by all elements you mean the oven and the stove top, then odds are high that you have a power input problem. The lights and clock/control board use 120 volts while the elements require the full 240 volts. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!!
__________________
| Display Modes | |
| wattage of heating elements | nmcclendon | Oven Repair (including Ranges and Cooktops) | 0 | 02-16-2010 12:12 PM |
| Heating elements do not come on. | Joseph Tackett | Dryer Repair | 1 | 05-19-2009 04:58 AM |
| Heating Elements not working | crazeeskier | Oven Repair (including Ranges and Cooktops) | 3 | 01-06-2009 10:18 PM |
| Heating elements | Yantelman | Oven Repair (including Ranges and Cooktops) | 1 | 12-23-2008 09:10 AM |
| whirlpool heating elements | grosen1107 | Dryer Repair | 1 | 01-24-2008 03:25 PM |
