Discuss
Sharp Range-cooktop burner will not turn off
 in
I have a ceramic glass cook-top electric range with built-in microwave drawer. I'm having an issue with
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Sharp Range-cooktop burner will not turn off
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-07-2008, 06:25 AM
JonoUNC89 JonoUNC89 is offline
Junior Member
JonoUNC89 is on a distinguished road
Default Sharp Range-cooktop burner will not turn off
Model Number: KB-3300J   Brand: -other-   Age: 1 - 5 years
I have a ceramic glass cook-top electric range with built-in microwave drawer. I'm having an issue with the right front burner not turning off when the knob is in the off position (The right front burner also has small and large cook areas controlled by the same knob). The first time this happened I noticed the hot surface indicator remained on longer than normal and it felt like the burner was putting off heat (although no red glow was seen). I unplugged the range, waited about 15 seconds and plugged back in. I then turned on the burner - large cook area. I saw a red light flash (kind of like when a light bulb burns out) in the center of the cook top (not where a burner is), then the right front burner turned on (glowing red). When I turn the knob to off the on/off indicator light went off but the burner remained on and glowing. I can unplug the range and repeat this process. The other burners appear to work normally as does using only the small cook area on the right front burner.
My questions are:
1.) what's causing this problem and how to fix?
2.) if I don't use the right front burner will it be safe to leave the range plugged in and use the remaining burners, oven, and microwave?
Jon
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-07-2008, 08:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jon,
Most likely the switch for this burner is shorted and I don't think it is safe to use the stove in such condition.
Unfortunately I'm not familiar with these models and I'm not able to provide more accurate advise. Hopefully someone else on this forum can help you better.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sparking Viking 6-Burner Cooktop Sharyn Oven Repair (including Ranges and Cooktops) 3 06-30-2008 09:53 PM
Chambers 4 burner gas cooktop- ignitor module dsdieeeorg Oven Repair (including Ranges and Cooktops) 2 03-22-2008 05:58 PM
burner wont turn off mos2571 Oven Repair (including Ranges and Cooktops) 0 02-15-2008 09:02 PM
Glass cooktop burned will not turn off. CELESTE RC Oven Repair (including Ranges and Cooktops) 10 01-24-2008 08:47 AM
GE Radiant Cooktop - Burner regulation NG Gabrielle Oven Repair (including Ranges and Cooktops) 2 01-19-2008 08:14 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
