it sometimes takes upto 6-8 minutes for the broiler to light. then sometimes it doesnt even light. I can see the ignitor glowing,I see differentpart numbers for the ignitor on different websites is it most likely the ignitor and what would be the right part number to get for replacement? thank you
Most likely the problem is a bad (weak) igniter. Your range made by Frigidaire and the OEM replacement igniter Part number: AP2125958
is very expensive. Instead you can use the igniter made by Whirlpool, which is absolutely the same. The only difference is - it comes without mounting bracket and you have to reuse the old one. You also might need high temperature porcelain wire nuts for the wire connection. - The Whirlpool igniter Part number: AP2934763
- The high temperature porcelain wire nuts Part number: AP3440673
The difference in price is more than $65. Gene.
