Discuss
whirlpool accubake oven
 in
My oven started beeping and turning off. Finally I saw a code e2f6 and took the panel apart to check
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » whirlpool accubake oven
  #1 (permalink)
Old 04-06-2008, 01:46 PM
Junior Member
lisaslusher is on a distinguished road
Default whirlpool accubake oven
Model Number: rbd275pdq12   Brand: Whirlpool   Age: 1 - 5 years
My oven started beeping and turning off. Finally I saw a code e2f6 and took the panel apart to check all the connections. It worked sporadically. I replaced the panel and it worked fine for about 2 weeks. Then the same thing started happening. Contol panels bite! I want to check the ground before I order the control board, but am unsure how to do that. Does this type of oven have a plug like a dryer? Any help would be appreciated. Thank you.
Lisa Slusher
Ads By Google
Related Models
Whirlpool RBD275PDQ12
Whirlpool RBD275PDQ13
Whirlpool RBD275PDQ14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ2
Whirlpool RBD275PDQ3
Whirlpool RBD275PDQ4
Whirlpool RBD275PDQ6
Whirlpool RBD275PDQ7
Whirlpool RBD275PDQ8
Whirlpool RBD275PDQ9
Whirlpool RBD275PDS12
Whirlpool RBD275PDS14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDS15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT10
Whirlpool RBD275PDT11
Whirlpool RBD275PDT12
Whirlpool RBD275PDT13
Whirlpool RBD275PDT14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT8
Whirlpool RBD275PDT9
Whirlpool RBD275PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS01 27" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool RBD275PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD276PDB1
Whirlpool RBD276PDB10
Whirlpool RBD276PDB11
Whirlpool RBD276PDB12
Whirlpool RBD276PDB2
Whirlpool RBD276PDB4
Whirlpool RBD276PDB6
Whirlpool RBD276PDB7
Whirlpool RBD276PDB8
Whirlpool RBD276PDB9
Whirlpool RBD276PDQ1
Whirlpool RBD276PDQ10
Whirlpool RBD276PDQ11
Whirlpool RBD276PDQ12
Whirlpool RBD276PDQ2
Whirlpool RBD276PDQ4
Whirlpool RBD276PDQ6
Whirlpool RBD276PDQ7
Whirlpool RBD276PDQ8
Whirlpool RBD276PDQ9
Whirlpool RBD277PDB1
Whirlpool RBD277PDB2
Whirlpool RBD277PDB4
Whirlpool RBD277PDQ1
Whirlpool RBD277PDQ2
Whirlpool RBD277PDQ4
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
  #2 (permalink)
Old 04-07-2008, 02:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Lisa,
Your oven does not have a plug and it should be hardwired. The junction box usually is behind the oven. You can find the complete wiring instructions in the installation manual.
Whirlpool recommendations concerning the "E2 - F6" error code are very uncertain. The cause of this problem could be control panel as well as control board without more specific diagnosis.
- The part number for the control board is AP3767567
Here are the break down diagrams for the Whirlpool oven Model RBD275PDQ12
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool accubake oven will not stay lit jonnelle419 Oven Repair (including Ranges and Cooktops) 0 11-09-2009 02:50 PM
Whirlpool Gold Accubake oven error code E0 -F2- sajajea Oven Repair (including Ranges and Cooktops) 1 09-26-2009 02:45 AM
Whirlpool Accubake Wall Oven shelirae Oven Repair (including Ranges and Cooktops) 1 02-02-2009 05:25 PM
Whirlpool Accubake dual oven--wont come back on bjersfamily Oven Repair (including Ranges and Cooktops) 1 01-28-2009 03:24 PM
Whirlpool Electric Accubake 465 range oven issue surpriseaz44 Oven Repair (including Ranges and Cooktops) 0 01-26-2009 08:52 PM
