Oven wont light-plenty of gas
When oven is called to pre-heat, ingnighter glows and smell of gas is present, but burner will not light. If oven door is closed, gas will build up and then ignite, bascillay a small explosion inside the oven. Leave the door open and "fan" the oven with a towel and burner will ignite just fine. Oven also seems to be taking longer to reach temp than normal. Broiler burner is working fine, no issues with that.
Any ideas where to start? |
| All times are GMT -7. The time now is 11:53 AM. |
