Discuss
KitchenAid Oven not maintaining Oven Temp
 in
I turn the oven on and control panel shows preheat cycle. Oven preheats fine but the oven won't maintain set
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » KitchenAid Oven not maintaining Oven Temp
  #1 (permalink)
Old 01-17-2010, 10:02 AM
Junior Member
Jane D is on a distinguished road
Default KitchenAid Oven not maintaining Oven Temp
Model Number: KEMC378KWHO   Brand: Kitchen Aid   Age: 5 - 10 years
I turn the oven on and control panel shows preheat cycle. Oven preheats fine but the oven won't maintain set temp. For ex. we set the oven for 350 deg. After preheat cycle, control panel shows 350; thermometer placed inside oven reads 350. 20 min later, control panel shows 350 but thermometer in oven reads 185 deg. Also, do you know where I can find a repair manual for this oven?
Thanks so much!
Ads By Google
Related Models
Whirlpool KEMI300SBL0
Whirlpool KEMI300SBL1
Whirlpool KEMI300VBL0
Whirlpool KEMI300VBL1
Whirlpool KEMI300VBL2
Whirlpool KEMI300VBL3
Whirlpool KEMI300VBL4
Whirlpool KEMI300VBL5
Whirlpool KEMI300WBL1
Whirlpool KEMI300WBL2
Whirlpool KEMI300WBL3
Whirlpool KEMI301BWH0
Whirlpool KEMI301GBL0
Whirlpool KEMI301GWH0
Whirlpool KEMI371BBL0
Whirlpool KEMI371BBL1
Whirlpool KEMI371BBL2
Whirlpool KEMI371BWH0
Whirlpool KEMI371BWH1
Whirlpool KEMI371BWH2
Whirlpool KEMI371GBL0
Whirlpool KEMI371GWH0
Whirlpool KEMI371SBL0
Whirlpool KEMI371TBL0
Whirlpool KEMI371TBL1
Whirlpool KEMI371TBL2
Whirlpool KEMI371TBL3
Whirlpool KEMI371XBL0
Whirlpool KEMI371XBL1
Whirlpool KEMI371XBL2
Whirlpool KEMI371YBL0
Whirlpool KEMI371YWH0
Whirlpool KEMS306BAL0
Whirlpool KEMS306BAL1
Whirlpool KEMS306BAL2
Whirlpool KEMS306BAL3
Whirlpool KEMS306BBL0
Whirlpool KEMS306BBL1
Whirlpool KEMS306BBL2
Whirlpool KEMS306BBL3
Whirlpool KEMS306BWH0
Whirlpool KEMS306BWH1
Whirlpool KEMS306BWH2
Whirlpool KEMS306BWH3
Whirlpool KEMS306XAL0
Whirlpool KEMS306XAL1
Whirlpool KEMS306XAL3
Whirlpool KEMS306XAL4
Whirlpool KEMS306XAL5
Whirlpool KEMS306XAL6
Whirlpool KEMS306XBL0
Whirlpool KEMS306XBL1
Whirlpool KEMS306XBL2
Whirlpool KEMS306XBL3
Whirlpool KEMS306XBL4
Whirlpool KEMS306XBL5
Whirlpool KEMS306XBL6
Whirlpool KEMS306XWH0
Whirlpool KEMS306XWH1
Whirlpool KEMS306XWH2
Whirlpool KEMS306XWH3
Whirlpool KEMS306XWH4
Whirlpool KEMS306XWH5
Whirlpool KEMS306XWH6
Whirlpool KEMS307DAL1
Whirlpool KEMS307DAL2
Whirlpool KEMS307DAL4
Whirlpool KEMS307DAL6
Whirlpool KEMS307DBL1
Whirlpool KEMS307DBL2
Whirlpool KEMS307DBL4
Whirlpool KEMS307DBL6
Whirlpool KEMS307DBS2
Whirlpool KEMS307DBS4
Whirlpool KEMS307DBS6
Whirlpool KEMS307DBT6
Whirlpool KEMS307DWH1
Whirlpool KEMS307DWH2
Whirlpool KEMS307DWH4
Whirlpool KEMS307DWH6
Whirlpool KEMS307GAL0
Whirlpool KEMS307GAL1
Whirlpool KEMS307GAL2
Whirlpool KEMS307GBL0
Whirlpool KEMS307GBL1
Whirlpool KEMS307GBL2
Whirlpool KEMS307GBL3
Whirlpool KEMS307GBL4
Whirlpool KEMS307GBS0
Whirlpool KEMS307GBS1
Whirlpool KEMS307GBS2
Whirlpool KEMS307GBS3
Whirlpool KEMS307GBS4
Whirlpool KEMS307GBT0
Whirlpool KEMS307GBT1
Whirlpool KEMS307GBT2
Whirlpool KEMS307GBT3
Whirlpool KEMS307GBT4
Whirlpool KEMS307GWH0
Whirlpool KEMS307GWH1
Whirlpool KEMS307GWH2
Whirlpool KEMS307GWH3
Whirlpool KEMS307GWH4
Whirlpool KEMS308GBL0
Whirlpool KEMS308GBL1
Whirlpool KEMS308GBL2
Whirlpool KEMS308GBL3
Whirlpool KEMS308GSS0
Whirlpool KEMS308GSS1
Whirlpool KEMS308GSS2
Whirlpool KEMS308GSS3
Whirlpool KEMS308GWH0
Whirlpool KEMS308GWH1
Whirlpool KEMS308GWH2
Whirlpool KEMS308GWH3
Whirlpool KEMS308SBL00 30" Built - in Electric Thermal Convection Combo Oven
Whirlpool KEMS308SSS00 30" Built - in Electric Thermal Convection Combo Oven
Whirlpool KEMS308SWH00 30" Built - in Electric Thermal Convection Combo Oven
Whirlpool KEMS375SBL0
Whirlpool KEMS375SBL1
  #2 (permalink)
Old 09-28-2010, 06:13 AM
Junior Member
serviceoven is on a distinguished road
Default KitchenAid Oven not maintaining oven temp
Jane D,
I am having a similar problem with a KitchenAid double oven (different model than yours). Did you ever determine the cause of the problem? Is the oven repaired and working normally now?
Thanks.
  #3 (permalink)
Old 09-28-2010, 08:30 AM
Junior Member
Default
There was a short in the heat element which caused it to be always on. Call Kitchenaid; this is a liability issue because it could cause a fire in the cabinet if it gets too hot. They paid for the labor to replace the element and I paid for the parts.
  #4 (permalink)
Old 09-28-2010, 02:54 PM
Junior Member
Default
I hope you don't mind if I ask one more question. Your original post seemed to indicate that an element was NOT coming on because the oven was not maintaining the proper temp. But in your recent reply, above, you say that the short in the heating element caused it to be ALWAYS on. I would have thought that an element always on would cause an overheated oven. Am I missing something?
Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven - F3 after replacing oven temp sensor robjcici Oven Repair (including Ranges and Cooktops) 16 01-08-2011 03:38 PM
GE Built-In Oven F2 Code Oven Temps Erratic & Over-Temp herbl Oven Repair (including Ranges and Cooktops) 0 02-26-2010 09:08 AM
kenmore oven will light, bring oven to temp, but won't re-light after the temp.... weedsnager Oven Repair (including Ranges and Cooktops) 1 12-02-2009 05:28 PM
Oven temp varies from display temp topxfuelx69 Oven Repair (including Ranges and Cooktops) 0 10-14-2009 01:45 PM
bake temp runaway code on a kitchenaid oven modemdog Oven Repair (including Ranges and Cooktops) 5 09-15-2008 01:53 PM
