Discuss
Help! Range Igniter Replacement
 in
One of the igniters on our range (one of the four top burners) is cracked and needs to be replaced.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Help! Range Igniter Replacement
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-04-2008, 01:09 PM
LSchm LSchm is offline
Junior Member
LSchm is on a distinguished road
Default Help! Range Igniter Replacement
Model Number: FGF374CCSG   Brand: Frigidaire   Age: 5 - 10 years
One of the igniters on our range (one of the four top burners) is cracked and needs to be replaced. I have already ordered and received it.
In my inital effort to remove the burner in order to replace the old igniter, one (1 of 3) of the sheet metal screws holding the burner in place sheared off at the screwhead. At this point I stopped to ask your advice.
1.) What is the proper way to replace the igniter on this range? From the top of the range? I do not see any other way? This was as I was trying to do when the screw broke off. Should I be spraying penetrating oil on the screw heads before removal?
2.) What should I do about the broken screwhead? Ignor or totally remove the burner (Again, how to do?) and use an e-z-out to remove the broken screw and re-attach?
Your advice would be really appreciated! Thank you for the help!
LSchm
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-04-2008, 05:09 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Common problem. Nothing to worry about
What techs normally do is drill the rest of the screw out (Sometimes on older models I had to drill out all 3 screws). Be careful not to damage the burner, use a small drill bit about the size of the screw. Replace the broken screw with a similar one.
You're on the right path. That's the only way to replace that igniter.
You probably already know this, but I'll mention it anway: do not use WD40 or anything else flammable to loosen screws on a stove.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Requesting help with a GE igniter replacement cfbeebe Oven Repair (including Ranges and Cooktops) 2 12-08-2007 10:26 AM
Range Hood Lights replacement/stuck pahaley Heating, Ventilation, and Air Conditioning (HVAC) 1 12-06-2007 11:28 AM
Gas Range Door Glass Replacement ronkat Oven Repair (including Ranges and Cooktops) 6 11-19-2007 06:54 PM
Igniter replacement wrightralph Oven Repair (including Ranges and Cooktops) 1 11-10-2007 11:17 AM
Glasstop replacement for range jmgrlg Oven Repair (including Ranges and Cooktops) 1 10-13-2007 11:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
