| » Cooktop - Get spark - no gas |
Model Number: SGCS304RS Brand: Thermador Age: 5 - 10 years
I have a Thermador SGCS304RS gas cooktop. The rear extralow burner sparks when I turn it on but there is no ignition. I do not smell gas so assume it is in the gas supply system. What can I do? Thanks, Andrew
Hello,
Most likely you have a potentiomer that's gone bad. The potentiometer is a switch that, among other things, sends voltage to a gas solenoid valve. Depending on the serial number of your cooktop, the part number will be one of the following: Serial number prior to 9705: 189819 Serial number of 9706 and after: 497235 The 497235 is a kit which includes both pots and a simmer control. All three parts will need to be replaced. KC |
This is most helpful. I will start my search for the parts. I am deeply appreciative for your problem ID.
Andrew Quote:
| Display Modes | |
| need spark for Rosieres gas cooktop | nccooker | Oven Repair (including Ranges and Cooktops) | 0 | 06-07-2009 11:32 AM |
| no spark thermador cooktop | abrooks | Oven Repair (including Ranges and Cooktops) | 0 | 12-03-2008 12:11 PM |
| no spark on cooktop | slicker30 | Oven Repair (including Ranges and Cooktops) | 0 | 04-14-2008 11:09 PM |
| GE gas cooktop igniter won't spark and lit | ewe | Oven Repair (including Ranges and Cooktops) | 1 | 03-04-2008 03:43 PM |
| GE gas cooktop igniter won't spark and lit | ewe | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2008 10:34 PM |
