Discuss
gas oven temp does not stay at set temp
 in
gas oven temperature is erractic. It doesn't maintain set temperature. There is no electronic control. Can the thermostat be replaced?
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » gas oven temp does not stay at set temp
  #1 (permalink)
Old 01-16-2010, 07:58 AM
Junior Member
rwarlock is on a distinguished road
Default gas oven temp does not stay at set temp
Model Number: 32-1009-00/07   Brand: Tappan   Age: More than 10 years
gas oven temperature is erractic. It doesn't maintain set temperature. There is no electronic control. Can the thermostat be replaced? Is that the problem? This stove is over 20 years old. Where would I find a replacement thermostat?
Ads By Google
Related Models
Frigidaire 32-1009-23-01 Tap(v2) / Gas Range
Frigidaire 32-1009-23-02 Tap(v4) / Gas Range
Frigidaire 32-1009-23-03 Tap(v6) / Gas Range
Frigidaire 32-1009-23-04 Tap(v2) / Gas Range
Frigidaire 32-1009-23-05 Tap(v4) / Gas Range
Frigidaire 32-1009-23-06 Tap(v2) / Gas Range
Frigidaire 32-1009-23-07 Tap(v2) / Gas Range
Frigidaire 32-1009-23-08 Tap(v4) / Gas Range
Frigidaire 32-1009-23-09 Tap(v2) / Gas Range
Frigidaire 32-1009-23-10 Tap(v4) / Gas Range
Frigidaire 32-1009-23-11 Tap(v2) / Gas Range
Frigidaire 32-1012-00-01 (v1)
Frigidaire 32-1012-00-02 (v2)
Frigidaire 32-1012-00-03 (v3)
Frigidaire 32-1012-00-04 (v4)
Frigidaire 32-1012-00-05 (v5)
Frigidaire 32-1012-00-06 (v6)
Frigidaire 32-1012-00-07 (v7)
Frigidaire 32-1012-00-08 (v8)
Frigidaire 32-1012-00-09 (v9)
Frigidaire 32-1012-00-10 (v10)
Frigidaire 32-1012-00-11 (v11)
Frigidaire 32-1012-00-12 (v12)
Frigidaire 32-1012-00-13 (v13)
Frigidaire 32-1012-23-01 (v14)
Frigidaire 32-1012-23-02 (v15)
Frigidaire 32-1012-23-03 (v16)
Frigidaire 32-1012-23-04 (v17)
Frigidaire 32-1012-23-05 (v18)
Frigidaire 32-1012-23-06 (v19)
Frigidaire 32-1012-23-07 (v20)
Frigidaire 32-1012-23-08 (v21)
Frigidaire 32-1012-23-09 (v22)
Frigidaire 32-1012-23-10 (v23)
Frigidaire 32-1012-23-11 (v24)
Frigidaire 32-1012-23-12 (v25)
Frigidaire 32-1012-23-13 (v26)
Frigidaire 32-1012-32-01 (v14)
Frigidaire 32-1012-32-02 (v15)
Frigidaire 32-1012-32-03 (v16)
Frigidaire 32-1012-32-04 (v17)
Frigidaire 32-1012-32-05 (v18)
Frigidaire 32-1012-32-06 (v19)
Frigidaire 32-1012-32-07 (v20)
Frigidaire 32-1012-32-08 (v21)
Frigidaire 32-1012-32-09 (v22)
Frigidaire 32-1012-32-10 (v23)
Frigidaire 32-1012-32-11 (v24)
Frigidaire 32-1012-32-12 (v25)
Frigidaire 32-1012-32-13 (v26)
Frigidaire 32-1012-45-01 (v1)
Frigidaire 32-1012-45-02 (v2)
Frigidaire 32-1012-45-03 (v3)
Frigidaire 32-1012-45-04 (v4)
Frigidaire 32-1012-45-05 (v5)
Frigidaire 32-1012-45-06 (v6)
Frigidaire 32-1012-45-07 (v7)
Frigidaire 32-1012-45-08 (v8)
Frigidaire 32-1012-45-09 (v9)
Frigidaire 32-1012-45-10 (v10)
Frigidaire 32-1012-45-11 (v11)
Frigidaire 32-1012-45-12 (v12)
Frigidaire 32-1012-45-13 (v13)
Frigidaire 32-1012-57-01 (v14)
Frigidaire 32-1012-57-02 (v15)
Frigidaire 32-1012-57-03 (v16)
Frigidaire 32-1012-57-04 (v17)
Frigidaire 32-1012-57-05 (v18)
Frigidaire 32-1012-57-06 (v19)
Frigidaire 32-1012-57-07 (v20)
Frigidaire 32-1012-57-08 (v21)
Frigidaire 32-1012-57-09 (v22)
Frigidaire 32-1012-57-10 (v23)
Frigidaire 32-1012-57-11 (v24)
Frigidaire 32-1012-57-12 (v25)
Frigidaire 32-1012-57-13 (v26)
Frigidaire 32-1012-66-01 (v1)
Frigidaire 32-1012-66-02 (v2)
Frigidaire 32-1012-66-03 (v3)
Frigidaire 32-1012-66-04 (v4)
Frigidaire 32-1012-66-05 (v5)
Frigidaire 32-1012-66-06 (v6)
Frigidaire 32-1012-66-07 (v7)
Frigidaire 32-1012-66-08 (v8)
Frigidaire 32-1012-66-09 (v9)
Frigidaire 32-1012-66-10 (v10)
Frigidaire 32-1012-66-11 (v11)
Frigidaire 32-1012-66-12 (v12)
Frigidaire 32-1012-66-13 (v13)
Frigidaire 32-1014-00-01 Tap(v1) / Gas Range
Frigidaire 32-1014-23-01 Tap(v2) / Gas Range
Frigidaire 32-1018-00-01 Tap(v1) / Gas Range
Frigidaire 32-1018-00-02 Tap(v3) / Gas Range
Frigidaire 32-1018-23-01 Tap(v2) / Gas Range
Frigidaire 32-1018-23-02 Tap(v4) / Gas Range
Frigidaire 32-1019-00-01 Tap(v1) / Gas Range
Frigidaire 32-1019-00-02 Tap(v3) / Gas Range
Frigidaire 32-1019-00-03 Tap(v1) / Gas Range
Frigidaire 32-1019-00-04 Tap(v3) / Gas Range
Frigidaire 32-1019-00-05 Tap(v5) / Gas Range
Frigidaire 32-1019-00-06 Tap(v1) / Gas Range
Frigidaire 32-1019-00-07 Tap(v1) / Gas Range
Frigidaire 32-1019-00-08 Tap(v1) / Gas Range
Frigidaire 32-1019-00-09 Tap(v3) / Gas Range
Frigidaire 32-1019-00-10 Tap(v1) / Gas Range
Frigidaire 32-1019-00-11 Tap(v3) / Gas Range
Frigidaire 32-1019-00-12 Tap(v1) / Gas Range
Frigidaire 32-1019-23-01 Tap(v2) / Gas Range
Frigidaire 32-1019-23-02 Tap(v4) / Gas Range
Frigidaire 32-1019-23-03 Tap(v2) / Gas Range
Frigidaire 32-1019-23-04 Tap(v4) / Gas Range
Frigidaire 32-1019-23-05 Tap(v6) / Gas Range
Frigidaire 32-1019-23-06 Tap(v2) / Gas Range
Frigidaire 32-1019-23-07 Tap(v2) / Gas Range
Frigidaire 32-1019-23-08 Tap(v2) / Gas Range
Frigidaire 32-1019-23-09 Tap(v4) / Gas Range
Frigidaire 32-1019-23-10 Tap(v2) / Gas Range
Frigidaire 32-1019-23-11 Tap(v4) / Gas Range
Frigidaire 32-1019-23-12 Tap(v2) / Gas Range
Frigidaire 32-1022-00-01 (v1)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore oven will light, bring oven to temp, but won't re-light after the temp.... weedsnager Oven Repair (including Ranges and Cooktops) 1 12-02-2009 05:28 PM
Oven temp varies from display temp topxfuelx69 Oven Repair (including Ranges and Cooktops) 0 10-14-2009 01:45 PM
freezer does not stay at temp jblaserman Refrigerator & Freezer Repair 2 08-07-2009 07:15 PM
Oven gets to temp, but won't stay there, unless a top burner is on too. bugaiho Oven Repair (including Ranges and Cooktops) 1 05-26-2009 07:51 PM
Oven won't stay at temp. Francis Rodrigue Oven Repair (including Ranges and Cooktops) 3 03-21-2008 05:58 PM
