Discuss
Sparking Viking 6-Burner Cooktop
 in
Our Viking 6-burner cooktop ... Model # VGSU160-6b-SS, purchased in October of 1996 ... has two problems. . PROBLEM 1:
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Sparking Viking 6-Burner Cooktop
  #1 (permalink)
Old 04-03-2008, 09:58 PM
Junior Member
Sharyn is on a distinguished road
Default Sparking Viking 6-Burner Cooktop
Model Number: VGSU160-6b-SS   Brand: -other-   Age: More than 10 years
PROBLEM 1: Part # 513 (spark switch #3 on the Wiring Diagram, located under the knob that controls the FRONT/MIDDLE burner) is cracked. After I have removed the knob to that burner, I can look down at the part, read the number, and see the crack.
This burner will ignite, but not in the usual way. To ignite it, I must turn the knob of another burner (to cause sparking) then turn the knob to this burner to cause gas flow. Then the burner functions normally.
PROBLEM 2: The FRONT/RIGHT burner, when used either alone or in combination with any one of the other five burners, causes either continual or intermittent sparking of the igniters. However, regarding the other five burners, when any one of them is used in combination with any other one of them, there is no continual or intermittent sparking.
To fix PROBLEM #1, is the only thing I need to do is replace # 513?
To fix PROBLEM #2, what do I need to do?
Ads By Google
Related Models
Amana VHC-2 Range - S/c S/i Ddraft Gas
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410
Thermador VM-450
Magic Chef VM11A-8P Mwave - Mounted Under Cabinet
Magic Chef VM11B-8P Mwave - Mounted Under Cabinet
Magic Chef VM11B-8PDY Mwave - Mounted Under Cabinet
Magic Chef VM11BN-8P Mwave - Mounted Under Cabinet
Magic Chef VM11C-8P Mwave - Mounted Under Cabinet
Magic Chef VM11CN-8P Mwave - Mounted Under Cabinet
Magic Chef VM11D-8P Mwave - Mounted Under Cabinet
Magic Chef VM11D-8P-DY Mwave - Mounted Under Cabinet
Magic Chef VM11DN-8P Mwave - Mounted Under Cabinet
Magic Chef VM11EB-8P Mwave - Mounted Under Cabinet
Magic Chef VM11EV-8P Mwave - Mounted Under Cabinet
Maytag VM12AB Mwave - Mounted Under Cabinet
Maytag VM12AM Mwave - Mounted Under Cabinet
Maytag VM12AV Mwave - Mounted Under Cabinet
Maytag VM12AV-1 Mwave - Mounted Under Cabinet
Thermador VM410
Magic Chef VM9B-8 Mwave - Mounted Under Cabinet
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000
Thermador VQT600
Whirlpool VR
Thermador VR-1000
Thermador VR-1400
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
Thermador VR1400
Frigidaire VR16
  #2 (permalink)
Old 05-26-2008, 10:56 PM
Member
Appliance repair in OC is on a distinguished road
Default
Could be spark module.
__________________
www.oc-repair.com
  #3 (permalink)
Old 05-27-2008, 01:43 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I would start at replacing defective spark switches and cleaning electrodes. Also check for bad insulation on the spark wires.
__________________
  #4 (permalink)
Old 06-30-2008, 09:53 PM
Member.
subcultures10 is on a distinguished road
Default
prob #1 are you speaking of the Top burner gas valve? Thats the only thing under the knobs if you have a vgsu model...
Far as the other, sounds like a faulty Module....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
One Burner not sparking brm98072 Oven Repair (including Ranges and Cooktops) 6 01-18-2011 12:54 PM
cooktop always sparking egonzalez Oven Repair (including Ranges and Cooktops) 7 08-01-2009 10:31 PM
Thermador Cooktop Sparking Matt Schauer Oven Repair (including Ranges and Cooktops) 16 06-30-2009 08:01 PM
GE burner sparking after spill mbmarsh Oven Repair (including Ranges and Cooktops) 1 05-27-2009 06:33 PM
spontaneous sparking of cooktop topaz Oven Repair (including Ranges and Cooktops) 1 06-06-2008 08:07 AM
