Discuss
Oven will not turn off
 in
I used the oven at lunch yesterday and turned it off when I was done but later in the day
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not turn off
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-23-2007, 04:15 AM
daugherr daugherr is offline
Junior Member
daugherr is on a distinguished road
Default Oven will not turn off
Model Number: ART663WW   Brand: Amana   Age: 5 - 10 years
I used the oven at lunch yesterday and turned it off when I was done but later in the day I noticed it was real hot aroung the stove. The temp readout on the panel was blank but the bottom heat coil was glowing red. I had to turn off the breaker to turn it off, there are two spots on the coil that look like weld spots and it still comes back on by itself when you turn the breaker on. After pulling the heating coil there is a hole burned through the bottom of it
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't turn on jdayseidel Oven Repair (including Ranges and Cooktops) 4 11-21-2007 04:59 PM
Broiler won't turn off!! knobjock Oven Repair (including Ranges and Cooktops) 0 08-14-2007 06:22 PM
Timer will not turn off rb8941 Dryer Repair 1 08-01-2007 10:11 PM
Dryer won't turn on ag1680 Dryer Repair 2 07-29-2007 08:57 PM
Agitator Won't Turn Manually? CAN I DO IT Washer Repair 1 07-27-2007 09:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
