I order an oriface kit to go from natural to LP gas from my parts people. They did not send an oriface for the oven, only the upper 4 burners. They say the safety valve is adjustable. So I took the oriface off the safey valve and all I see is a triangular piece of steel with a hole in the center. Should I try and remove this by unscrewing or pulling it out?
How can I make this adjustment? Is there an adjustment on this oven, or do I need an oriface for the oven? The flame is toooo big without it. The upper buners are fine with the orifaces I installed yesterday..
Please let me know... ND
The oven burner flame can be adjusted by slowly turning the orifice CW or CCW.
