| » Oven turns off |
What is the complete model number of the range?
What does the display show when it turns off? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Maytag Performa Model PGR5710BDW.
The oven turns on and heats up. The oven temp shows 400 then after 3-4 minutes the oven turns off, then after 30 seconds the panel will show the time blinking. We can turn the oven back on but it will continue to turn off. Thanks Matt |
Hi Matt,
Sounds like the problem is a bad control board. - The control board Part number: AP4396588 Here is the Service manual. Here are the breakdown diagrams and Replacement parts for MAYTAG PGR5710BDW Range - S/c F/s Gas | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| oven turns on and off by itself | arin | Oven Repair (including Ranges and Cooktops) | 3 | 12-07-2009 01:29 PM |
| Oven turns itself off | PastorJohn | Oven Repair (including Ranges and Cooktops) | 3 | 07-17-2009 03:59 PM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| oven turns on with out a tem being set | pmeyer60 | Oven Repair (including Ranges and Cooktops) | 1 | 09-23-2008 12:17 PM |
| Clock turns on when the oven is turned on but oven doesn't work | LMesey | Oven Repair (including Ranges and Cooktops) | 2 | 08-22-2008 11:20 AM |
