Discuss
GE gas cooktop igniter probelm
 in
I have GE gas cooktop (modele#JGP328WEC2WW). I had an issue where one of the igniter kept firing even when
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE gas cooktop igniter probelm
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-02-2008, 03:15 PM
Manish Manish is offline
Junior Member
Manish is on a distinguished road
Default GE gas cooktop igniter probelm
Model Number: JGP328WEC2WW   Brand: GE   Age: 5 - 10 years
I had an issue where one of the igniter kept firing even when knob is
in off position. I learned that it could be bad switch. So i bought new harness switch (GE part# WB18T10339) and replaced it. Here are few things i would like to know.
1. old switch were rectangle. New switches are square. Has GE changed design ?
2. old switch would sit perpendicular to gas pipe underneath. New switch are at an angle (about 22 degree). Is this expected.
3. Is there any instruction to install this switch. First i connected two ends of switch to spark module , eveything worked. I swapped two connections and it still works. I thought i should just work one or the other way not both ways.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-03-2008, 01:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
GE did change design (and part number) for the switch harness.
One wire (anyone) should go to the spark module and the other one should go to the power inlet. You had to use the two terminals where the old wires have been connected.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE gas cooktop igniter won't spark and lit ewe Oven Repair (including Ranges and Cooktops) 1 03-04-2008 03:43 PM
GE gas cooktop igniter won't spark and lit ewe Oven Repair (including Ranges and Cooktops) 0 03-01-2008 10:34 PM
cooktop igniter wont work Dwayne landrum Oven Repair (including Ranges and Cooktops) 1 02-07-2008 04:53 PM
Igniter Deb Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:09 AM
Igniter Deb Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:01 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
