Discuss
Stove top non-stop clicking
 in
Appreciate any help to stop the non-stop clicking noise. I have done the following so far with no effect:
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Stove top non-stop clicking
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-01-2008, 08:46 PM
CharlesonZone CharlesonZone is offline
Junior Member
CharlesonZone is on a distinguished road
Default Stove top non-stop clicking
Model Number: JGBP30BEW1AD   Brand: GE   Age: 5 - 10 years
a. opened up the top cover and see no problem with the wire or the electrodes.
b. clean each of the 4 electrodes.
c. Take out the control knobs and blow dry each.
Also, I cannot turn off the power for the stove itself without shutting off other lights and applicances. Is it dangeous to let it click all the time? If I push in the knob and turn it to lite, it will fire up normally.
Charleson
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-02-2008, 03:15 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If your burner elecrodes are sparking all the time, one of your control switches is shorted.
__________________
  #3 (permalink)
Old 04-02-2008, 03:25 PM
Junior Member
Default
Hi, thanks for the tip.....
Look like I will need to order the right part to replace them. Any particular things I need to be careful of in replacing the old ones?
Thanks again.
  #4 (permalink)
Old 04-02-2008, 04:35 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
The switch just slides on to the burner valve and is
held in place with two plastic tabs. Just take a bit
of care so as to not break the tabs. You will need
to isolate which switch is actually causing the problem
before you actually order any parts.
You can simply disconnect one wire on each switch
until you get the one stops the igniters. Make sure
the bare end of the wire is not touching you or ground.
  #5 (permalink)
Old 04-03-2008, 06:40 PM
Junior Member
Default
Hi:
Very helpful.... I find the trouble-maker and got it out.
Now, try to find the right part:
I find the following in this site. The part name is a bit confusing (valve?). Can you let me know if this is the right one to order? Thanks a lot.
Switch burner valve
Part Number: AP2023926 made by GE
Mfg # seems to be WB24K14 or WB24K16??
  #6 (permalink)
Old 04-04-2008, 12:30 PM
Senior Expert
APP Volunteer
Default
The GE part number you need is WB24K14.
The AP2023926 number that it crosses
over to is merely a stock number that the
parts supplier uses.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Anoying clicking! chaps Oven Repair (including Ranges and Cooktops) 1 02-09-2008 09:32 PM
Ice maker clicking kchemers Refrigerator & Freezer Repair 1 02-06-2008 03:37 PM
clicking noise stevecr Refrigerator & Freezer Repair 0 11-18-2007 05:10 AM
No clicking from one burner Joepilot Oven Repair (including Ranges and Cooktops) 4 08-30-2007 05:36 AM
Gas Stove Clicking curtisclm Oven Repair (including Ranges and Cooktops) 2 08-10-2007 08:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
