Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Oven wouldn't stay heated, now won't heat up at all (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/68815-oven-wouldnt-stay-heated-now-wont-heat-up-all.html)
AnnetteD 01-12-2010 07:03 PM
Propane Gas Oven would not heat up consistently. It would heat up to desired temp, then start losing heat (although display still read desired temp). Replaced the gas valve, part # AP4279176. Worked fine for a few days, then started losing heat again. Then oven stopped heating up altogether. Burners still work just fine. Any suggestions before I call a repairman to find out whether it should be fixed or replaced?
