| » GE F3 sensor replaced but still get error F3 |
Model Number: JTP15BDBB Brand: GE Age: More than 10 years
like others I've read, I have a GE oven with F3 code after about 40 min at 400F. I replaced the sensor and check wires. I'm lost. I have never seen a response that addresses the problem after these steps were taken. Now what?! |
There is an issue with with those connectors. First try cutting out the connectors. Using the correct size wire nuts or but-end connectors hard wire sensor. Also make sure connection at the erc is ok. After that if you're still having trouble it's likely your erc (electronic range control) is giving a faulty reading, and will need to be replaced.
| Display Modes | |
| Replaced keypad, | Meomaxy | Oven Repair (including Ranges and Cooktops) | 1 | 01-13-2008 12:38 AM |
| heat sensor bad? | karaokemom@tds.net | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2008 07:44 PM |
| Sensor Dry Mode | drew | Dryer Repair | 1 | 12-13-2007 08:32 PM |
| Location of sensor? | Gil | Dishwasher Repair | 3 | 11-29-2007 09:38 AM |
| Sensor Pad | Duke | Dryer Repair | 0 | 10-06-2007 10:41 AM |
