Discuss
ge gas oven will not light
 in
top burners light okay. oven burner will not light and appears gas valve does not open and ignitor does not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ge gas oven will not light
  #1 (permalink)
Old 01-11-2010, 05:08 PM
Junior Member
roy_l is on a distinguished road
Default ge gas oven will not light
Model Number: jgbs15ger5   Brand: GE   Age: 5 - 10 years
top burners light okay. oven burner will not light and appears gas valve does not open and ignitor does not spark. I get 120v through oven control switch. gas valve coil appears okay (contunity). ignitor measures open. is there a test for the ignitor?
Ads By Google
Related Models
General Electric JGBS15GER5 Gas range
General Electric JGBS15GER6 Gas range
General Electric JGBS15GER7 Gas range
General Electric JGBS15GPK1 Electric range
General Electric JGBS15GPK3 Gas range
General Electric JGBS15PEA1AD Gas range
General Electric JGBS15PEA1WH Gas range
General Electric JGBS15PEA2AD Gas range
General Electric JGBS15PEA2WH Gas range
General Electric JGBS15PEA3AD Gas range
General Electric JGBS15PEA3WH Gas range
General Electric JGBS15PEW1AD Gas range
General Electric JGBS15PEW1WH Gas range
General Electric JGBS15PK1 Gas range
General Electric JGBS15PK3 Gas range
General Electric JGBS16EH1 Electric range
General Electric JGBS16EH2 Gas range
General Electric JGBS16EH3 Gas range
General Electric JGBS16EJ1 Gas range
General Electric JGBS16EJ2 Gas range
General Electric JGBS16GEH1 Gas range
General Electric JGBS16GEH2 Gas range
General Electric JGBS16GEH3 Gas range
General Electric JGBS16GEJ1 Electric range
General Electric JGBS16GEJ2 Gas range
General Electric JGBS16GEP1
General Electric JGBS16GEP1BB Gas range
General Electric JGBS16GEP2 Gas range
General Electric JGBS16GEP3 Gas range
General Electric JGBS16GEP4 Gas range
General Electric JGBS16GEP5 Gas range
General Electric JGBS16GEP6 Gas range
General Electric JGBS16GEP7 Gas range
General Electric JGBS16GPH1 Gas range
General Electric JGBS16GPH2 Electric range
General Electric JGBS16GPH3 Gas range
General Electric JGBS16GPJ1 Gas range
General Electric JGBS16GPJ2 Gas range
General Electric JGBS16PH1 Gas range
General Electric JGBS16PH2 Gas range
General Electric JGBS16PH3 Gas range
General Electric JGBS16PJ1 Gas range
General Electric JGBS16PJ2 Gas range
General Electric JGBS16WEP1WW Gas range
General Electric JGBS17BEL1BB Gas range
General Electric JGBS17EV1AD Gas range
General Electric JGBS17EV1WH Gas range
General Electric JGBS17EV2AD Gas range
General Electric JGBS17EV2WH Gas range
General Electric JGBS17EV3AD Gas range
General Electric JGBS17EV3WH Gas range
General Electric JGBS17EV4AD Gas range
General Electric JGBS17EV4WH Gas range
General Electric JGBS17GER1 Gas range
General Electric JGBS17GER2 Gas range
General Electric JGBS17GER3 Gas range
General Electric JGBS17GER4 Gas range
General Electric JGBS17GER5 Gas range
General Electric JGBS17PEA1AD Gas range
General Electric JGBS17PEA1CT Gas range
General Electric JGBS17PEA1WH Gas range
General Electric JGBS17PEA2AD Gas range
General Electric JGBS17PEA2CT Gas range
General Electric JGBS17PEA2WH Gas range
General Electric JGBS17PEA3AD Gas range
General Electric JGBS17PEA3CT Gas range
General Electric JGBS17PEA3WH Gas range
General Electric JGBS17PEA4WH Gas range
General Electric JGBS17PEA5WH Gas range
General Electric JGBS17PEH1CT Gas range
General Electric JGBS17PEH1WH Gas range
General Electric JGBS17PEH2CT Gas range
General Electric JGBS17PEH2WH Gas range
General Electric JGBS17PEK1WW Gas range
General Electric JGBS17PEK2WW Gas range
General Electric JGBS17PEW1AD Gas range
General Electric JGBS17PEW1WH Gas range
General Electric JGBS17PEW2AD Gas range
General Electric JGBS17PEW2WH Gas range
General Electric JGBS18EV1WW Gas range
General Electric JGBS18EV2WW Gas range
General Electric JGBS18EV3WW Gas range
General Electric JGBS18EV4WW Gas range
General Electric JGBS18GEJ1 Electric range
General Electric JGBS18GEJ2 Gas range
General Electric JGBS18GEJ3 Gas range
General Electric JGBS18GEJ4 Gas range
General Electric JGBS18GEJ5 Gas range
General Electric JGBS18GEJ6 Gas range
General Electric JGBS18GEJ7 Gas range
General Electric JGBS18GES1 Gas range
General Electric JGBS18GES2 Gas range
General Electric JGBS18GES3 Gas range
General Electric JGBS19BEH1CT Gas range
General Electric JGBS19BEH1WH Gas range
General Electric JGBS19BEH2CT Gas range
General Electric JGBS19BEH2WH Gas range
General Electric JGBS19GEP1 Gas range
General Electric JGBS19GEP2 Gas range
General Electric JGBS19GEP3 Gas range
General Electric JGBS19GEP4 Gas range
General Electric JGBS19GEP5 Gas range
General Electric JGBS19GEP6 Gas range
General Electric JGBS20BEA1AD Gas range
General Electric JGBS20BEA1CT Gas range
General Electric JGBS20BEA1WH Gas range
General Electric JGBS20BEA2AD Gas range
General Electric JGBS20BEA2WH Gas range
General Electric JGBS20BEA3AD Gas range
General Electric JGBS20BEA3WH Gas range
General Electric JGBS20BEA4AD Gas range
General Electric JGBS20BEA4WH Gas range
General Electric JGBS20BEA5AD Gas range
General Electric JGBS20BEA5WH Gas range
General Electric JGBS20BEH1CT Gas range
General Electric JGBS20BEH1WH Gas range
General Electric JGBS20BEH2CT Gas range
General Electric JGBS20BEH2WH Gas range
General Electric JGBS20BEW1AD Gas range
General Electric JGBS20BEW1WH Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 4 01-30-2011 08:26 PM
Blinking Blue Lights (Oven ON Light & Oven Heating Light bubbah2os Oven Repair (including Ranges and Cooktops) 1 02-05-2010 01:07 PM
kenmore oven will light, bring oven to temp, but won't re-light after the temp.... weedsnager Oven Repair (including Ranges and Cooktops) 1 12-02-2009 05:28 PM
Oven doesn't light, Broil and Preheat will light tisears Oven Repair (including Ranges and Cooktops) 1 09-09-2009 12:38 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
