Discuss
Oven and broiler won't ignite
 in
Was working fine last week then something quietly died. I browsed the forum but din't find what I needed. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven and broiler won't ignite
  #1 (permalink)
Old 01-11-2010, 03:48 PM
Junior Member
royw7621 is on a distinguished road
Default Oven and broiler won't ignite
Model Number: FGFL77ABD   Brand: Frigidaire   Age: 5 - 10 years
I did measure the ohms across the broiler igniter, I think.
102 ohms
I do not have a parts layout to be sure that was it even.
I do have the schematics from the back side of the range.
So, I'd like to see the parts layout I could print out, please. Couldn't print the one online.
Anyways...the top burners work just fine...
I'm guessing that the igniter isn't getting the signal from the EOC?
Not gonna guess my way through this one.
Your help would be greatly appreciated.
Thank you,
Roy
Related Models
Frigidaire FGFL77ABD Frigidaire/gas Range
Frigidaire FGFL77ABE Frigidaire/gas Range
Frigidaire FGFL77ABF Frigidaire/gas Range
Frigidaire FGFL77ABH Frigidaire/gas Range
Frigidaire FGFL77ABJ Frigidaire/gas Range
Frigidaire FGFL77AQB Frigidaire/range
Frigidaire FGFL77AQC Frigidaire/range
Frigidaire FGFL77AQD Frigidaire/gas Range
Frigidaire FGFL77AQE Frigidaire/gas Range
Frigidaire FGFL77AQF Frigidaire/gas Range
Frigidaire FGFL77AQH Frigidaire/gas Range
Frigidaire FGFL77AQJ Frigidaire/gas Range
Frigidaire FGFL77ASB Frigidaire/range
Frigidaire FGFL77ASC Frigidaire/range
Frigidaire FGFL77ASD Frigidaire/gas Range
Frigidaire FGFL77ASE Frigidaire/gas Range
Frigidaire FGFL77ASF Frigidaire/gas Range
Frigidaire FGFL77ASH Frigidaire/gas Range
Frigidaire FGFL77ASJ Frigidaire/gas Range
Frigidaire FGFL79DBA Frigidaire/gas Range
Frigidaire FGFL79DBB Frigidaire/range
Frigidaire FGFL79DBC Frigidaire/range
Frigidaire FGFL79DBE Frigidaire/range
Frigidaire FGFL79DBF Frigidaire/range
Frigidaire FGFL79DBG Frigidaire/range
Frigidaire FGFL79DBH Frigidaire/range
Frigidaire FGFL79DCA Frigidaire/gas Range
Frigidaire FGFL79DCB Frigidaire/gas Range
Frigidaire FGFL79DCC Frigidaire/range
Frigidaire FGFL79DCD Frigidaire/range
Frigidaire FGFL79DQA Frigidaire/gas Range
Frigidaire FGFL79DQB Frigidaire/range
Frigidaire FGFL79DQC Frigidaire/range
Frigidaire FGFL79DQE Frigidaire/range
Frigidaire FGFL79DQF Frigidaire/range
Frigidaire FGFL79DQG Frigidaire/range
Frigidaire FGFL79DQH Frigidaire/range
Frigidaire FGFL79DSA Frigidaire/gas Range
Frigidaire FGFL79DSB Frigidaire/range
Frigidaire FGFL79DSC Frigidaire/range
Frigidaire FGFL79DSE Frigidaire/range
Frigidaire FGFL79DSF Frigidaire/range
Frigidaire FGFL79DSG Frigidaire/range
Frigidaire FGFL79DSH Frigidaire/range
Frigidaire FGFL79ECA Frigidaire/gas Range
Frigidaire FGFL79ECB Frigidaire/gas Range
Frigidaire FGFL79ECD Frigidaire/range
Frigidaire FGFL79FCA Frigidaire/gas Range
Frigidaire FGFL79FCB Frigidaire/range
Frigidaire FGFL79FCC Frigidaire/range
Frigidaire FGFL79GBA GAS RANGE
Frigidaire FGFL79GBB GAS RANGE
Frigidaire FGFL79GBC GAS RANGE
Frigidaire FGFL79GBD GAS RANGE
Frigidaire FGFL79GBE GAS RANGE
Frigidaire FGFL79GBF GAS RANGE
Frigidaire FGFL79GCA GAS RANGE
Frigidaire FGFL79GCB GAS RANGE
Frigidaire FGFL79GCC GAS RANGE
Frigidaire FGFL79GCD GAS RANGE
Frigidaire FGFL79GCE GAS RANGE
Frigidaire FGFL79GCF GAS RANGE
Frigidaire FGFL79GCG GAS RANGE
Frigidaire FGFL79GCH GAS RANGE
Frigidaire FGFL79GQA GAS RANGE
Frigidaire FGFL79GQB GAS RANGE
Frigidaire FGFL79GQC GAS RANGE
Frigidaire FGFL79GQD GAS RANGE
Frigidaire FGFL79GQE GAS RANGE
Frigidaire FGFL79GQF GAS RANGE
Frigidaire FGFL79GSA GAS RANGE
Frigidaire FGFL79GSB GAS RANGE
Frigidaire FGFL79GSC GAS RANGE
Frigidaire FGFL79GSD GAS RANGE
Frigidaire FGFL79GSE GAS RANGE
Frigidaire FGFL79GSF GAS RANGE
Frigidaire FGFL83DQA Frigidaire/gas Range
Frigidaire FGFL83DQB Frigidaire/range
Frigidaire FGFL83DQE Frigidaire/gas Range
Frigidaire FGFL83DSA Frigidaire/gas Range
Frigidaire FGFL83DSB Frigidaire/range
Frigidaire FGFL83DSE Frigidaire/gas Range
Frigidaire FGFL87DCA Frigidaire/gas Range
Frigidaire FGFL87DCB Frigidaire/gas Range
Frigidaire FGFL87DCC Frigidaire/range
Frigidaire FGFL87DCD Frigidaire/range
Frigidaire FGFL87DCE Frigidaire/range
Frigidaire FGFL87DCF Frigidaire/gas Range
Frigidaire FGFL87DCG Frigidaire/range
Frigidaire FGFL87DQA Frigidaire/gas Range
Frigidaire FGFL87DQB Frigidaire/range
Frigidaire FGFL87DQC Frigidaire/range
Frigidaire FGFL87DQE Frigidaire/range
Frigidaire FGFL87DQF Frigidaire/range
Frigidaire FGFL87DQG Frigidaire/range
Frigidaire FGFL87DSA Frigidaire/gas Range
Frigidaire FGFL87DSB Frigidaire/range
Frigidaire FGFL87DSC Frigidaire/range
Frigidaire FGFL87DSE Frigidaire/range
Frigidaire FGFL87DSF Frigidaire/range
Frigidaire FGFL87DSG Frigidaire/range
Frigidaire FGFL87GSA GAS RANGE
Frigidaire FGFL87GSB GAS RANGE
Frigidaire FGFL87GSC GAS RANGE
Frigidaire FGFL87GSD GAS RANGE
Frigidaire FGFL87GSE GAS RANGE
Frigidaire FGFL87GSF GAS RANGE
Frigidaire FGFL87GSG GAS RANGE
Frigidaire FGFL87GSH GAS RANGE
Frigidaire FGFL88ACA Frigidaire/gas Range
Frigidaire FGFL88ACB Frigidaire/gas Range
Frigidaire FGFL88ACC Frigidaire/gas Range
Frigidaire FGFL88ASA Frigidaire/gas Range
Frigidaire FGFL88ASB Frigidaire/gas Range
Frigidaire FGFL89CCA Frigidaire/gas Range
Frigidaire FGFL89CCB Frigidaire/gas Range
Frigidaire FGFLMC55ECA Frigidaire/gas Range
Frigidaire FGFLMC55ECB Frigidaire/range
Frigidaire FGFLMC55ECC Frigidaire/range
Frigidaire FGFLMC55GCA GAS RANGE
  #2 (permalink)
Old 01-11-2010, 04:08 PM
gabe_1981's Avatar
Senior Expert
APP Volunteer
gabe_1981 is on a distinguished road
Default
Have you tested 120 vac to your ignitor? If correct voltage is present to the ignitor, when controls are set to bake, replace the ignitor.
Back to Results
Igniter kit for oven burner, flat style. - By Frigidaire. Length - 3.72". Replaces any flat oven igniter (excluding blue ceramic igniters).
Part Number: AP2150412
Made by FRIGIDAIRE Our Price: $41.64
Compare at: $65.23
You Save: $23.59
In Stock
Order now and it will ship Tuesday
Quantity
__________________
Case Appliance Repair College Station,Texas-
  #3 (permalink)
Old 01-11-2010, 05:38 PM
Junior Member
Default Frigidaire range won't ignite oven or broiler
I checked the voltage going to the igniter and it's only 6.7 VAC.
The indicator lights do come on and the preheat light comes on after a few seconds too. Still no flames.
  #4 (permalink)
Old 01-11-2010, 05:59 PM
gabe_1981's Avatar
Senior Expert
APP Volunteer
Default
If your not getting 120 VAC to your ignitor when set to preheat or bake and I hate to be the burden of bad news but it sounds like a control board issue ... 6.7 VAC is incorrect voltage.
Back to Results
Clock
Part Number: AP3672819
Made by FRIGIDAIRE Our Price: $158.06
Compare at: $186.51
You Save: $28.45
In Stock
Quantity
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana oven & broiler quit at the same time- won't ignite js-everett Oven Repair (including Ranges and Cooktops) 1 06-08-2009 12:17 PM
Whirelpool oven and broiler wont ignite Prithpal Oven Repair (including Ranges and Cooktops) 1 06-02-2009 05:23 PM
Oven/Broiler won't ignite DMC Oven Repair (including Ranges and Cooktops) 1 08-18-2008 02:28 PM
Have to use broiler to make oven ignite eighty8s Oven Repair (including Ranges and Cooktops) 0 02-23-2008 01:36 PM
Oven and Broiler ignite then shut off after 2 seconds Steve Smith Oven Repair (including Ranges and Cooktops) 2 01-21-2008 04:31 PM
