Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   gas oven pop sound (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/68448-gas-oven-pop-sound.html)
Antonius 01-11-2010 01:03 PM
gas oven pop sound
I have a magic chef gas range model 3458kvw; when the oven is on it makes a pop sound every 5 or 10 seconds and it takes a long time to reach desired temperature; I want to fix it; what can i do to repair it
Gene 01-11-2010 02:04 PM
How long time takes to light up the burner since you turn the control ON?
If it takes more than 70 seconds, replace the oven igniter (#9 on the diagram).
Remove the Bake burner and check for a burned through holes. Make sure all fire holes are clean.
- The oven Bake igniter Part number: AP4012072
- The Bake burner Part number: AP4093607
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 3458KVW Range - S/c F/s Gas | AppliancePartsPros.com
