Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   General Electric gas oven (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/6838-general-electric-gas-oven.html)
onenwalsh 03-31-2008 02:28 PM
I have a General Electric gas oven JGBP35, the oven does not get up to the proper heat. I changed the Tempature sensor and it still doesn't work. The oven egnitor works the burner goes on for 10-20 seconds and then turns off, about 3-4 minutes later it goes back on for 10-20 seconds. Any ideas?
Gene 04-01-2008 03:19 PM
Most likely the problem is a bad oven control. In order to provide the right part number I need the rest of the model number.
victor borcea 04-02-2008 04:32 AM
same problem
I have same problem but nobody want to help me and i have the exact model nr.I think the don`t know.
onenwalsh 04-02-2008 12:30 PM
Quote:
Hi Gene,
Thanks for responding. The entire model number is JGBP35GEP3WG
Gene 04-02-2008 05:49 PM
Hi onenwalsh,
The part number for the control board (without overlay) is AP2632694
The overlay is no longer available. You have to be careful not to damage it when you'll remove it from the old control board. It is selfadhesive.
