The left front burner sparks when the control knob is turned off and also occassionly when this knob is off and one of the right side burners is in use. Both the left burnes have in this model the function to cycle on and off while in use for low heating. More recently the left front burner stops working while in use. It ignites ok, but then stops. This does not happen all the time but is getting more frequent. Any suggestions? Thanks for your assistance
