I need help figuring out the wiring on a GE JV624 vent hood. I have Black and white coming in for power supply. White is hooked directly to lamp. The lamp also has an orange wire that should connect to switch and one open pole for a wire from the motor(?). Switch has control for light and fan with 4 poles for attaching wires numbered 1-3 and 6. Three wires come from the motor: red, white, black. Any thoughts? Thanks.
