Discuss
electric range/oven clock not working
 in
led lights on clock do not work - oven heats.. do we need to replace the entire clock assembly or just
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electric range/oven clock not working
  #1 (permalink)
Old 07-20-2007, 07:17 PM
50fbn 50fbn is offline
Junior Member
50fbn is on a distinguished road
Default electric range/oven clock not working
Model Number: 911 4674 591   Brand: Kenmore   Age: 5 - 10 years
led lights on clock do not work - oven heats.. do we need to replace the entire clock assembly or just the touchpad?
Related Models
Kenmore 911.04698680  KENMORE ELECTRIC RANGE
Kenmore 911.04698690  KENMORE ELECTRIC RANGE
Kenmore 911.3202090  GAS COUNTER UNIT
Kenmore 911.3202091  30" GAS COUNTER UNIT
Kenmore 911.32080100  30" GAS COOKTOP
Kenmore 911.32085890  30" GAS COUNTER UNIT
Kenmore 911.32088890  30" GAS COUNTER UNIT
Kenmore 911.32089890  30" GAS COUNTER UNIT
Kenmore 911.3212590  30" GAS COUNTER UNIT
Kenmore 911.3212990  30" GAS COUNTER UNIT
Kenmore 911.32212100  COOKTOP
Kenmore 911.32212101  30" GAS COOKTOP
Kenmore 911.32214100  COOKTOP
Kenmore 911.32214101  30" GAS COOKTOP
Kenmore 911.32219100  COOKTOP
Kenmore 911.32219101  30" GAS COOKTOP
Kenmore 911.32222100  36" GAS COOKTOP
Kenmore 911.32222101  36" GAS COOKTOP
Kenmore 911.32224100  36" GAS COOKTOP
Kenmore 911.32224101  36" GAS COOKTOP
Kenmore 911.32229100  36" GAS COOKTOP
Kenmore 911.32229101  36" GAS COOKTOP
Kenmore 911.32255590  30" GAS COUNTER UNIT
Kenmore 911.32255591  30" GAS COUNTER UNIT
Kenmore 911.32255592  30" GAS COUNTER UNIT
Kenmore 911.32259590  30" GAS COUNTER UNIT
Kenmore 911.32259591  30" GAS COUNTER UNIT
Kenmore 911.32285890  30" GAS COUNTER UNIT
Kenmore 911.32289890  30" GAS COUNTER UNIT
Kenmore 911.32355590  30" GAS COUNTER UNIT
Kenmore 911.32355591  30" GAS COUNTER UNIT
Kenmore 911.32356590  30" GAS COUNTER UNIT
Kenmore 911.32356591  30" GAS COUNTER UNIT
Kenmore 911.32359590  30" GAS COUNTER UNIT
Kenmore 911.32359591  30" GAS COUNTER UNIT
Kenmore 911.32384101  30" GAS COOKTOP
Kenmore 911.32385100  30" GAS COOKTOP
Kenmore 911.32385890  30" GAS COUNTER UNIT
Kenmore 911.32386890  30" GAS COUNTER UNIT
Kenmore 911.32389100  30" GAS COOKTOP
Kenmore 911.32389890  30" GAS COUNTER UNIT
Kenmore 911.3522190  GAS RANGE
Kenmore 911.3524190  KENMORE - 30" DROP-IN RANGE
Kenmore 911.3528611  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 911.3528810  DROP IN GAS RANGE
Kenmore 911.3528812  DROP IN GAS RANGE
Kenmore 911.3542090  DROP-IN GAS RANGE
Kenmore 911.3544090  KENMORE 30" DROP-IN RANGE
Kenmore 911.3548691  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 911.3548810  KENMORE GAS RANGE
Kenmore 911.3548813  DROP-IN GAS RANGE
Kenmore 911.3611190  GAS RANGE
Kenmore 911.3618810  KENMORE 30 IN GAS RANGE
Kenmore 911.3618811  GAS RANGE
Kenmore 911.3618890  KENMORE 30 IN GAS RANGE
Kenmore 911.3628610  KENMORE GAS RANGE
Kenmore 911.3628611  KENMORE GAS RANGE
Kenmore 911.3628690  KENMORE GAS RANGE
Kenmore 911.3628710  KENMORE GAS RANGE
Kenmore 911.3631990  GAS RANGE
Kenmore 911.3632090  SLIDE-IN RANGE
Kenmore 911.3638611  KENMORE GAS RANGE
Kenmore 911.3638690  KENMORE GAS RANGE
Kenmore 911.3638710  KENMORE GAS RANGE
Kenmore 911.3638810  KENMORE GAS RANGE
Kenmore 911.3638811  30" GAS RANGE
Kenmore 911.3638812  GAS RANGE
Kenmore 911.3651190  Slide-In Range, Gas
Kenmore 911.3652090  GAS RANGE
Kenmore 911.3652091  GAS RANGE
Kenmore 911.3652190  GAS RANGE
Kenmore 911.3652191  GAS RANGE
Kenmore 911.3654090  30" SELF-CLEANING OVEN
Kenmore 911.3654190  KENMORE 30" GAS SELF-CLEAN RANGE
Kenmore 911.3654191  30" SELF-CLEANING OVEN
Kenmore 911.3658610  KENMORE GAS RANGE
Kenmore 911.3658611  KENMORE GAS RANGE
Kenmore 911.3658690  KENMORE GAS RANGE
Kenmore 911.3658691  KENMORE GAS RANGE
Kenmore 911.3658790  KENMORE GAS RANGE
Kenmore 911.3658812  GAS RANGE
Kenmore 911.36655591  30" GAS SLIDE-IN RANGE
Kenmore 911.36655792  30" GAS SLIDE-IN RANGE
Kenmore 911.36655793  30" GAS SLIDE-IN RANGE
Kenmore 911.36655794  30" GAS SLIDE-IN RANGE
Kenmore 911.36655795  30" GAS SLIDE-IN RANGE
Kenmore 911.36659791  30" GAS SLIDE-IN RANGE
Kenmore 911.36659792  30" GAS SLIDE-IN RANGE
Kenmore 911.3672590  30" SLIDE-IN GAS RANGE
Kenmore 911.3672591  GAS SLIDE-IN RANGE
Kenmore 911.3672990  30" SLIDE-IN GAS RANGE
Kenmore 911.3672991  GAS SLIDE-IN RANGE
Kenmore 911.3678855  GAS RANGE
Kenmore 911.3678856  GAS RANGE
Kenmore 911.3678857  GAS RANGE
Kenmore 911.3678895  GAS RANGE
Kenmore 911.3678896  GAS RANGE
Kenmore 911.4229290  ELECTRIC COOKTOP
Kenmore 911.4242090  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242091  ELECTRIC COUNTER UNIT
Kenmore 911.4242092  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242190  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242191  ELECTRIC COUNTER UNIT
Kenmore 911.4242192  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242590  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242591  ELECTRIC COUNTER UNIT
Kenmore 911.4242592  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242791  30" ELECTRIC COUNTER UNIT
Kenmore 911.42455590  30" ELECTRIC COUNTER UNIT
Kenmore 911.42456590  30" ELECTRIC COUNTER UNIT
Kenmore 911.42459590  30" ELECTRIC COUNTER UNIT
Kenmore 911.42474100  30" COUNTER UNIT
Kenmore 911.42475890  30" COUNTER UNIT
Kenmore 911.42476890  30" COUNTER UNIT
Kenmore 911.42479890  30" COUNTER UNIT
Kenmore 911.4252590  ELECTRIC COUNTER UNIT
Kenmore 911.4252990  ELECTRIC COUNTER UNIT
Kenmore 911.42612100  30" RADIANT COUNTER UNIT
Kenmore 911.42617100  30" RADIANT COUNTER UNIT
Kenmore 911.42619100  30" RADIANT COUNTER UNIT
  #2 (permalink)
Old 07-21-2007, 12:47 AM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
You'll need to replace the clock in order to fix the problem. Unfortunately, you'll need to replace the touch pad as well, because on this model the touch pad is actually not a functional part, just a sticker with labels (buttons) on it. If you try to stick the old touch pad on the new clock, it won't stay on very long. At least it's pretty cheap - about $13-$15.
Clock for your model (Your Kenmore range was made by GE by the way): Part Details - GE Clock, part number: AP2025145
Touch pad:
White: Part Details - GE Clock plate, part number: AP2632115
Black: Part Details - GE Clock plate, part number: AP2632114
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
