Discuss
Replace sensor on Kenmore oven
 in
I need to replace sensor on my oven. I have found the part but wonder how hard this is to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replace sensor on Kenmore oven
  #1 (permalink)
Old 03-29-2008, 03:40 PM
Junior Member
Cobbler is on a distinguished road
Default Replace sensor on Kenmore oven
Model Number: 629.46795   Brand: Kenmore   Age: 5 - 10 years
I need to replace sensor on my oven. I have found the part but wonder how hard this is to do myself.
Related Models
Jenn-Air 629.46965 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 629.46969 RANGE- S/C S/I DDRAFT ELE
Hardwick 629.70131 RANGE- F/S STD GAS
Hardwick 629.70138 RANGE- F/S STD GAS
Hardwick 629.70231 RANGE- F/S STD GAS
Hardwick 629.70238 RANGE- F/S STD GAS
Jenn-Air 629.80515 MISC / ACCESSORY
Jenn-Air 629.80519 MISC / ACCESSORY
Kenmore 62912103 COOKTOPS
Kenmore 62912104 COOKTOPS
Kenmore 62920245 ELECTRIC/GAS SLIDE-IN RANGE
Kenmore 62921136 Built-In Oven, Electric
Kenmore 62921137 Built-In Oven, Electric
Kenmore 62921238 WALL OVEN
Kenmore 62921239 WALL OVEN
Kenmore 62921336 WALL OVEN
Kenmore 62922001 COOKTOP
Kenmore 62922112 COOKTOPS
Kenmore 62922113 COOKTOPS
Kenmore 62922114 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922115 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922116 ELECTRIC COOKTOP
Kenmore 62922401 COOKTOP
Kenmore 62942015 COIL MODULE
Kenmore 62942019 COIL MODULE
Kenmore 62942025 GLASS CARTRIDGE
Kenmore 62942029 GLASS CARTRIDGE
Kenmore 62942032 GRIDDLE MODULE
Kenmore 62942035 GRILL COVER
Kenmore 62942039 GRILL COVER
Kenmore 62942765 ELECTRIC COOKTOP
Kenmore 62942769 ELECTRIC COOKTOP
Kenmore 62942865 ELECTRIC COOKTOP
Kenmore 62942869 ELECTRIC COOKTOP
Kenmore 62942975 COUNTER UNIT
Kenmore 62942975790 COUNTER UNIT
Kenmore 62942979 COUNTER UNIT
Kenmore 62942979790 COUNTER UNIT
Kenmore 6294576 ELECTRIC SLIDE-IN RANGE
Kenmore 62945765 ELECTRIC RANGE
Kenmore 62945765690 ELECTRIC RANGE
Kenmore 62945765790 ELECTRIC RANGE
Kenmore 62945766790 ELECTRIC RANGE
Kenmore 62945769790 ELECTRIC RANGE
Kenmore 62945775 KENMORE COOKING
Kenmore 62945776 KENMORE COOKING
Kenmore 62945779 KENMORE COOKING
Kenmore 62946775690 ELECTRIC RANGE
Kenmore 62946775790 ELECTRIC RANGE
Kenmore 62946776790 ELECTRIC RANGE
Kenmore 62946779790 ELECTRIC RANGE
Kenmore 62946795 ELECTRIC RANGE
Kenmore 62946796 ELECTRIC RANGE
Kenmore 62946799 ELECTRIC RANGE
Kenmore 62946965 ELECTRIC RANGE
Kenmore 62946969 ELECTRIC RANGE
Kenmore 6294697 ELECTRIC RANGE
Kenmore 62946975 WIRING DIAGRAM-RANGE
Kenmore 62946979 WIRING DIAGRAM-RANGE
Kenmore 62960002600 KENMORE COOKING
Kenmore 62960002601 KENMORE COOKING
Kenmore 62960002606 ELECTRIC RANGE
Kenmore 62960003600 KENMORE COOKING
Kenmore 62960008600 KENMORE COOKING
Kenmore 62960008601 KENMORE COOKING
Kenmore 62960008606 ELECTRIC RANGE
Kenmore 62960009600 KENMORE COOKING
Kenmore 62960009601 KENMORE COOKING
Kenmore 62960009606 ELECTRIC RANGE
Kenmore 62970131 GAS RANGE
Kenmore 62970138 GAS RANGE
Kenmore 62990131 ELECTRIC RANGE
Kenmore 62990138 ELECTRIC RANGE
Kenmore 629CG200 GAS COOKTOP
Magic Chef 62S14XAA RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAS RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAW RANGE- S/I CONT CLEAN GAS
Hoover 63
Amana 630.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.002 RANGE- S/C S/I DDRAFT GAS
Amana 630.003 RANGE- S/C S/I DDRAFT GAS
Frigidaire 6307B WASHER
Frigidaire 6308A WASHER
Frigidaire 6309A WASHER
Amana 631.000 RANGE- S/C S/I DDRAFT GAS
Amana 631.001 RANGE- S/C S/I DDRAFT GAS
Amana 631.002 RANGE- S/C S/I DDRAFT GAS
Amana 631.003 RANGE- S/C S/I DDRAFT GAS
Amana 631.004 RANGE- S/C S/I DDRAFT GAS
Amana 631.006 RANGE- S/C S/I DDRAFT GAS
Amana 632-3J ROOM AIR CONDITIONER
Frigidaire 6337B WASHER
Frigidaire 6338A WASHER
Frigidaire 6339A WASHER
Hoover 634
Frigidaire 6347B WASHER
Frigidaire 6348A WASHER
Frigidaire 6358A WASHER
Frigidaire 6389-80A WASHER
Frigidaire 6389-80B WASHER
Frigidaire 6389-87A WASHER
Frigidaire 6389-87B WASHER
Hoover 64
Maytag 640C DRYER- GAS
Maytag 640W DRYER- GAS
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
Kenmore 6476037260 KENMORE 30 IN GAS RANGE
Kenmore 6476037310 KENMORE 30 IN GAS RANGE
Kenmore 6476037311 KENMORE 30 INCH GAS RANGE
Kenmore 6476037312 KENMORE 30 IN GAS RANGE
  #2 (permalink)
Old 04-26-2008, 05:30 PM
Junior Member
JackSnodgrass is on a distinguished road
Default
Why do you think that you need to replace the sensor? I have the same
model unit ( or very similar ) and after the last cleaning, the display
reads F1. The Fan comes on as soon as you plug it in and it shows F1.
It resets after about 30 seconds, the fan goes off and the display
clears... and then it does the same F1/Fan thing for 30 seconds in an
endless loop.
I think that the sensor is bad... but I don't know for sure. The tek guide
that was on the oven said to put the temp down to 100deg and get a
2nd code... but the oven resets before I can get it down past 160deg.
I have removed my sensor ( more on that later.. . ) and put an ohm
meter on it.. it reads 64.00 K Ohms.... I think that is 64000 ohms and
the stuff I've read said that it should be around 1,000 ohms at room
temp. I've cooled the temp sensor in my freezer and it went from 64K
to 99K... I placed it near some heat.. and it went from 64K to 40K.
I'm not really sure what all that means....
I found a replacement sensor on the Internet for $50... that seems kind
of pricey for what I've got in my hands.... I'd like more confirmation that
my sensor is bad before I spend $50 and find out it's something else.
To remove the sensor...
remove power... if you don't... you may die....
pull the unit away from the wall
remove the two silver screws from the top left and top right side
of the big, silver panel that covers up the back of the unit.
on the left side of the unit ( when facing the front... the power plug
goes on the right side... ) in the back is a pair of yellow/cream colored
wires. There are two sets of holes... they come out from the top set and
go in through the bottom hole.... they are loose and can be pulled out
from the top hole... gently pull them out and there is a disconnect plug...
disconnect the wires be separating the plug. Then go in from the 'oven'
part of the range and inside the main oven unit on the left top, is a 6"
copper tube that is secured by 2 screws. It is sticking out like a spear...
remove those two screws and gently pull it out. The back side will have
those yellow/cream colored wires... you'll need to get that connector
through the insulation / hole and you'll be all set.
I've got my probe... but I'm not sure if it's my problem or not...
Jack
  #3 (permalink)
Old 04-26-2008, 06:20 PM
Junior Member
Thanks Jack. We did go ahead and figure out how to replace the sensor. Oven is working great. The F1 code indicated the control but we took a chance on the sensor and it worked.
  #4 (permalink)
Old 04-26-2008, 07:23 PM
Junior Member
Default
Quote:
did you get the F1/FAN/RESET over and over again too?
jack
  #5 (permalink)
Old 04-27-2008, 05:57 AM
Junior Member
Default
The fan kept running with the F1 in the display. We tried cancel then tried to start over and it would kick off and display F1 with fan running.
  #6 (permalink)
Old 04-29-2008, 10:41 AM
Junior Member
Default
Just wanted to post my results. I got a new sensor from a local maytag
store... I guess that the maytag and kenmore people share things ( they
may even be made by the same group ) and the 74003390 part I needed
was supplied by the maytag part: 12001656. I installed it, got my oven
back together and it works fine. Before I installed it, I tested it with my
ohm meter and it read 1K -vs- the 64K that my bad probe read. The 1K
reading was the expected one. I asked the guy if the sensor went out
a lot and he said that it must... or he wouldn't stock that part. Maybe
the self-cleaning stuff just isn't worth it.
jack
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Temp Sensor ~ Find & Replace lrcdmc@sbcglobal.net Dishwasher Repair 2 12-03-2009 12:03 PM
Show Me How to replace Jenn-air oven sensor shokwaves Oven Repair (including Ranges and Cooktops) 3 10-26-2009 07:26 PM
How to replace oven sensor? donsmullen Oven Repair (including Ranges and Cooktops) 1 07-11-2009 01:57 PM
How do you replace an oven sensor? kschrei Oven Repair (including Ranges and Cooktops) 1 05-31-2009 06:39 PM
Need to replace sensor in lower oven fleabagh Oven Repair (including Ranges and Cooktops) 0 03-03-2009 12:33 PM
