partsman1
#1 Posted : Friday, January 8, 2010 9:44:27 AM(UTC)
partsman1
Does anyone know if Whirlpool part # 9751895 can be used in place of # 9751894. 9751894 has been discontinued.
#2 Posted : Friday, January 8, 2010 10:52:37 AM(UTC)
Replacement parts for WHIRLPOOL KGRT507GBL0 | AppliancePartsPros.com
I would say no but am not 100% sure about this.
If you zoom in on the following picture you can see under the reflection that the key layout and number of keys are different.
You could replace it with a white panel which is available.
Hopefully someone will jump in who knows for sure.
Here is 9751894 (AP2994604)
Part number: AP2994604
Here is 9751895 (AP29959675)
Part number: AP2995675
Have you tried the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
partsman1
#3 Posted : Saturday, January 9, 2010 4:28:33 PM(UTC)
partsman1
denman, Thanks for the advice. I had already purchased a new clock control circuit board. I installed that and cleaned the conecting strip as you suggested and made sure I had a good connection. Everything appears to be working fine now.
Thanks again,
Partsman
#4 Posted : Sunday, January 10, 2010 1:18:39 AM(UTC)
Which keypad did you purchase?
It would be interesting to know if the alternate keypad did work correctly in this unit.
thanks in advance
Guest (8)
