the right front electronic ignitor on my gas range top isnt working properly, if i look straight down inside the porcelin igniter i can see spark at bottom however nothin at the top. The igniter is about one inch long and has a small metal tip protruding from the top of the center of the porcelin where it appears the spark should emanate. when i went to two different parts dealers they gave me a partnumber, which is 8053720 for the replacement igniter however, they dont match, the one they gave me is shorter, fatter and has no little metal tip protruding about 1/16 of aninch out of the top center of the porcelin, any suggestions? John
