Discuss
Wall oven will not heat/re-heat properly
 in
I have a Frigidaire convetion wall oven, PLEB30T8CCB , that will not heat properly. At first I noticed it was
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wall oven will not heat/re-heat properly
  #1 (permalink)
Old 01-07-2010, 09:47 AM
Junior Member
dottavio is on a distinguished road
Default Wall oven will not heat/re-heat properly
Model Number: PLEB30T8CCB   Brand: Frigidaire   Age: 1 - 5 years
I have a Frigidaire convetion wall oven, PLEB30T8CCB, that will not heat properly.
At first I noticed it was too cool. After reading the manual I reset the temp up 25 degrees.
That seemed to bring the oven up to the correct temperature, but when you try and reset the temp higher via the control panel the temperature will not change on the panel and changes very slowly in the oven, but will not reach to correct temperature.
We have had power surges, though none lately. It appears to be a wear problem. We use the upper oven often. The lower oven seems to be working fine.
Anyway to determine if it is the control panel or the baking element?
Ads By Google
Related Models
Frigidaire PLEB30T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB30T9DCA Frigidaire/electric Walloven
Frigidaire PLEB30T9DCB Frigidaire/wall Oven
Frigidaire PLEB30T9DCC Frigidaire/walloven
Frigidaire PLEB30T9FCA Frigidaire/wall Oven
Frigidaire PLEB30T9FCB Frigidaire/walloven
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFZ398ECA Frigidaire/electric Range
Frigidaire PLEFZ398ECB Frigidaire/electric Range
Frigidaire PLEFZ398ECC Frigidaire/range
Frigidaire PLEFZ398ECD Frigidaire/electric Range
Frigidaire PLEFZ398ECE Frigidaire/range
Frigidaire PLEFZ398ECF Frigidaire/range
Frigidaire PLES389ACA Frigidaire/electric Range
Frigidaire PLES389ACB Frigidaire/electric Range
Frigidaire PLES389ACC Frigidaire/electric Range
Frigidaire PLES389ACD Frigidaire/electric Range
Frigidaire PLES389CCA Frigidaire/electric Range
Frigidaire PLES389CCB Frigidaire/electric Range
Frigidaire PLES389CCC Frigidaire/electric Range
Frigidaire PLES389DCA Frigidaire/electric Range
Frigidaire PLES389DCB Frigidaire/electric Range
Frigidaire PLES389DCC Frigidaire/electric Range
Frigidaire PLES389DCD Frigidaire/electric Range
Frigidaire PLES389DCE Frigidaire/electric Range
Frigidaire PLES389ECB Frigidaire/electric Range
Frigidaire PLES389ECC Frigidaire/electric Range
Frigidaire PLES389ECD Frigidaire/electric Range
Frigidaire PLES389ECE Frigidaire/range
Frigidaire PLES389ECF Frigidaire/electric Range
Frigidaire PLES389ECG Frigidaire/electric Range
Frigidaire PLES389ECH Frigidaire/electric Range
Frigidaire PLES399ECB Frigidaire/electric Range
Frigidaire PLES399ECC Frigidaire/electric Range
Frigidaire PLES399ECD Frigidaire/range
Frigidaire PLES399ECE Frigidaire/electric Range
Frigidaire PLES399ECF Frigidaire/electric Range
Frigidaire PLES399ECG Frigidaire/electric Range
Frigidaire PLEW27S3ECA Frigidaire/warmer Drawer
Frigidaire PLEW27S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3ACA Frigidaire/warmer Drawer
Frigidaire PLEW30S3CCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCB Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCB Frigidaire/warmer Drawer
Frigidaire PLFU1777DS0 Frigidaire/freezer
Frigidaire PLFU1777DS1 Frigidaire/freezer
Frigidaire PLFU1777DS2 Frigidaire/freezer
Frigidaire PLFU1778ES0 Frigidaire/freezer
Frigidaire PLFU1778ES1 Frigidaire/freezer
Frigidaire PLFU1778ES2 Frigidaire/freezer
Frigidaire PLFU2067DS0 Frigidaire/freezer
Frigidaire PLFU2067DS1 Frigidaire/freezer
Frigidaire PLFU2067DS2 Frigidaire/freezer
Frigidaire PLFU2067DS3 Frigidaire/freezer
Frigidaire PLFU2067DS4 Frigidaire/freezer
Frigidaire PLGC30S8ACA Frigidaire/cooktop
Frigidaire PLGC30S8CCA Frigidaire/gas Cooktop
Frigidaire PLGC30S8CCB Frigidaire/gas Cooktop
Frigidaire PLGC30S9ECA Frigidaire/gas Cooktop
Frigidaire PLGC36S9ACA Frigidaire/cooktop
Frigidaire PLGC36S9CCA Frigidaire/gas Cooktop
Frigidaire PLGC36S9CCB Frigidaire/gas Cooktop
Frigidaire PLGC36S9ECA Frigidaire/gas Cooktop
Frigidaire PLGF389ACA Frigidaire/gas Range
Frigidaire PLGF389ACB Frigidaire/gas Range
Frigidaire PLGF389ACC Frigidaire/gas Range
Frigidaire PLGF389ACD Frigidaire/gas Range
Frigidaire PLGF389CCA Frigidaire/gas Range
Frigidaire PLGF389CCB Frigidaire/gas Range
Frigidaire PLGF389CCC Frigidaire/gas Range
Frigidaire PLGF389CCD Frigidaire/gas Range
Frigidaire PLGF389CCE Frigidaire/gas Range
Frigidaire PLGF390DCA Frigidaire/gas Range
Frigidaire PLGF390DCB Frigidaire/range
Frigidaire PLGF390DCC Frigidaire/range
Frigidaire PLGF390DCD Frigidaire/range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat properly pocahontas Oven Repair (including Ranges and Cooktops) 1 02-25-2010 08:39 AM
Help..New Frigidaire wall oven won't heat properly mrbluegrass Oven Repair (including Ranges and Cooktops) 0 05-18-2009 06:36 PM
whirlpool DBL OVN - top oven will not heat properly univsocal Oven Repair (including Ranges and Cooktops) 0 03-06-2009 08:01 PM
Need Help With Frigidaire Oven--Won't Heat Properly wpaxt Oven Repair (including Ranges and Cooktops) 1 01-16-2009 06:24 AM
Oven does not heat properly badhearty Oven Repair (including Ranges and Cooktops) 3 11-10-2008 02:34 PM
