Discuss
Whrilpool SC8900EX only one burner lights
 in
My gas cooktop will only light the front left burner. The other switches had been making the spark igniter click,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whrilpool SC8900EX only one burner lights
  #1 (permalink)
Old 03-28-2008, 09:37 AM
ScottB ScottB is offline
Junior Member
ScottB is on a distinguished road
Default Whrilpool SC8900EX only one burner lights
Model Number: SC8900EX   Brand: Whirlpool   Age: More than 10 years
My gas cooktop will only light the front left burner. The other switches had been making the spark igniter click, but no flame. I switched the left and right modules and the left front was still the only one that would light. So it didn't matter which burner module was there, the front left always works and the others do not. So the spark igniter is working properly and I need to work my way back from here to see what is causing this problem. What is the next thing to check? Thanks for your help.
ScottB
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-29-2008, 10:41 AM
Active Appliance Active Appliance is offline
Expert
APP Volunteer
Active Appliance is on a distinguished road
Default
Next, try replacing spark electrode. You can do the same switching technique with it.
Hope this helps,
Dmitriy
__________________
Active Appliances, Inc. Professional appliance repair services in Los Angeles and Ventura counties.
  #3 (permalink)
Old 04-03-2008, 09:00 AM
Junior Member
Default
I bought one switch igniter and replaced my front right burner switch but it still did not light. I pulled my new switch igniter from there and placed it on the back left. When I attempted to light it, it also did not work. I noticed when I attempted to light the burners, that I had a small black wire arcing to the shield switch. The wire did not appear to be cut in any way, just too close to the shield switch. I was able to tie it off to the rest of the wiring bundle and now all the burners are lighting once again. Thanks for the help. I really enjoy the forum.
ScottB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Burner Lights then Sputters markwidz Oven Repair (including Ranges and Cooktops) 2 02-04-2008 07:04 PM
lights work-nothing else does! momstaxi Dishwasher Repair 3 01-16-2008 06:41 PM
no lights Andyindra Refrigerator & Freezer Repair 1 12-17-2007 07:41 PM
Lights do not turn on dgulbin@optonline.net Microwave Repair 1 10-13-2007 03:29 AM
Working, but no lights geckomon Refrigerator & Freezer Repair 2 09-11-2007 09:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
