I replaced the two igniters on the oven as it would not heat up. It seems to be working fine now but the oven temp is off as I checked it with a oven thermometer. a seting of 350 degrees produces a temp of 400 and a setting of 275 makes a temp of 350. is this a calibration problem and how do I accomplsh this.
