Discuss
Oven Not Staying at Temp
 in
The range is a double oven model. The top oven will heat up, but then not hold the temp. Bottom
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Not Staying at Temp
  #1 (permalink)
Old 03-27-2008, 02:42 PM
MikeDiehl MikeDiehl is offline
Junior Member
MikeDiehl is on a distinguished road
Default Oven Not Staying at Temp
Model Number: MER6872BAQ   Brand: Maytag   Age: 5 - 10 years
The range is a double oven model. The top oven will heat up, but then not hold the temp. Bottom element does not come on. Same thing happened about four years ago and I think that the control unit (clock) was replaced.
Is there an easy way to troubleshoot to find out if it's the burner or control board? Is this a problem with Maytag? Should it still be covered by the parts warranty?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven temp rising hmartin0532 Oven Repair (including Ranges and Cooktops) 0 12-26-2007 08:24 AM
Oven temp off shea11 Oven Repair (including Ranges and Cooktops) 0 12-03-2007 01:11 PM
oven temp too low leon Oven Repair (including Ranges and Cooktops) 2 10-05-2007 04:18 PM
Gas Dryer Not Staying Hot hcjr Dryer Repair 3 09-11-2007 04:17 PM
Oven Temp 60F low George Whitmore Oven Repair (including Ranges and Cooktops) 0 08-13-2007 04:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
