Discuss
replacing board for clock and oven
 in
How do you replace the board that controls the clock and oven at the top.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replacing board for clock and oven
  #1 (permalink)
Old 03-27-2008, 02:24 PM
mtroegel mtroegel is offline
Junior Member
mtroegel is on a distinguished road
Default replacing board for clock and oven
Model Number: FEF365CGBD   Brand: Frigidaire   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-27-2008, 02:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Before we proceed I would like to know what is the original problem with your range.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-30-2008, 11:38 AM
Junior Member
Default replacing clock & oven control pad
This just started,but I have found that every time I turn the tv on the clock on the oven either starts blinking or trys to go out. And you also can't use the oven when this is going on. I have been through this about 25 times but every time the t.v. is turned on the clock goes acting up. I have even tried turning the t.v. on without a remote but the same problem . And also, the oven is on it's on power wired to it's on electic box outside. SO CAN YOU PLEASE TELL ME WHAT THIS IS!!!!!!!!!!!!!!!!!!!! P.S. This sounds like something Rod Stirling would have in the TWLIGHT ZONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #4 (permalink)
Old 03-31-2008, 11:28 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think there is a problem with the oven control board.
Most likely something is wrong with power supply for the oven and/or TV. You have to call a certified electrician to check the breaker box and the outlets inside.
__________________
  #5 (permalink)
Old 04-01-2008, 11:46 PM
Junior Member
Default
Thankyou, Iguess I will have to do that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wiring diagram for clock/control board Aaron Richardson Oven Repair (including Ranges and Cooktops) 0 02-08-2008 11:26 AM
Replacing control panel circuit board vickie Dishwasher Repair 1 01-14-2008 03:51 AM
GE electronic clock/oven control ANiforos Oven Repair (including Ranges and Cooktops) 2 12-12-2007 08:26 PM
GE Oven Clock needs replacing Mary Smoker Oven Repair (including Ranges and Cooktops) 0 12-07-2007 07:24 PM
Oven and clock not working maryc Oven Repair (including Ranges and Cooktops) 1 11-11-2007 04:53 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
