Bob M
#1 Posted : Tuesday, January 5, 2010 5:12:54 PM(UTC)
Bob M
Today the oven took over 10 minutes to preheat to 210 degrees. We had the temp set for 375. The broiler element works fine so I'm sure I just need to replace the oven element. Is that correct?
#2 Posted : Tuesday, January 5, 2010 5:49:39 PM(UTC)
Replacement parts for Art6610WW models | AppliancePartsPros.com
Cannot say for sure.
Best way is to unplug/remove power from the unit, remove the element and check it with a meter.
If open (infinite ohms) it is shot.
It is a good idea to clip something (clothespin etc) to the wires before removing them from the element so they do not disappear into the back of the oven.
Bob M
#3 Posted : Tuesday, January 5, 2010 6:36:40 PM(UTC)
Bob M
Thanks. My son noticed yesterday that the element was glowing in one spot so I'm pretty sure thats the problem area. I'll get a testor and see.
