Discuss
GE error code F3
 in
Wow theres gota be a forum for everything. Well I am one of those jack of all trades and master
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE error code F3
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-26-2008, 05:55 PM
Mako Mako is offline
Junior Member
Mako is on a distinguished road
Default GE error code F3
Model Number: JB940A0B1AA   Brand: GE   Age: 1 - 5 years
Wow theres gota be a forum for everything. Well I am one of those jack of all trades and master of none type of guys I have a GE prophile model JB940A0B1AA ( closest thing that comes up is JB940AB1AA which is the same I am guessing ). Anyway I get the F3 error code so I am thinking I need the new sensor. I removed the sensor and put my meter on the sensor side of the plug and it came to the 1 for the ohms when I put it on the other side of the plug I get 8. I did allot of reading here and still can't figure out if that a good or bad thing. Thanks for your help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-27-2008, 10:15 AM
Junior Member
Default
Any body know what the ohm readings mean?
  #3 (permalink)
Old 03-27-2008, 06:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The "F3" error code means the oven sensor is open.
An ohmmeter reading for the open circuit should be "∞".
Resistance should be measured across both wires.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
- The part number for the oven sensor is AP2023862
Here are the break down diagrams for the GE range Model JB940AB1AA
__________________
Professional appliance repair services in Orange County, California.
  #4 (permalink)
Old 04-01-2008, 06:10 PM
Junior Member
Default
Well I just replaced the sensor. I unplugged the stove waited a couple minutes plugged it back in and it still doesn't work back to the f3 error any ideas?
  #5 (permalink)
Old 04-01-2008, 07:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you check the sensor before you replaced it?
If you did, what was the result?
__________________
  #6 (permalink)
Old 04-01-2008, 07:57 PM
Junior Member
Default
Wow thanks for the quick responce Gene. Yep I put the info in my first post I got a ohm reading of 1 on the sensor and a reading of 8 on the plug it plugs into.
  #7 (permalink)
Old 04-01-2008, 08:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unplug the sensor plug from the control board and measure resistance across the sensor terminals at this plug. Post the result.
__________________
  #8 (permalink)
Old 04-02-2008, 06:48 PM
Junior Member
Default
Ok that one is about 7.5. I cheched the wire from the sensor plug to the control board plug and those wires are good too.
  #9 (permalink)
Old 04-02-2008, 07:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mako,
Something is wrong. The resistance must be much more then 7.5 Ohms.
As you said the sensor is new and there is nothing wrong with wires.
THERE IS NOTHING ELSE.
How did you check the sensor resistance?
Did you read this article :How to check continuity with Ohmmeter?
__________________
  #10 (permalink)
Old 04-02-2008, 07:22 PM
Junior Member
Default
Yep read the article and set my anolog meter to 0. I put my ohm meter probe in the backside of the sensors plug the old sensor and the new one both read the same 1. I checked the two pins on the board where the probes wires would be pluged into again and it reads 8 now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 Error Code Eva Oven Repair (including Ranges and Cooktops) 1 02-18-2008 11:27 AM
Error Code F10 UncleKenny Oven Repair (including Ranges and Cooktops) 3 01-28-2008 08:04 PM
F 1 Error Code Frogburk Oven Repair (including Ranges and Cooktops) 1 08-29-2007 02:10 PM
e-10 error code hoogabooga Washer Repair 0 08-28-2007 02:57 PM
F2 - Error Code Wilson Oven Repair (including Ranges and Cooktops) 3 08-23-2007 09:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
