Discuss
Oven fails to ignite: igniter, spark module or safety valve?
 in
Top burners, ignition work fine. Oven dead. I set the oven temp, there's an initial double-click sound, but then no
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven fails to ignite: igniter, spark module or safety valve?
  #1 (permalink)
Old 01-05-2010, 05:02 PM
Junior Member
davidinnh is on a distinguished road
Default Oven fails to ignite: igniter, spark module or safety valve?
Model Number: mgr4452bds   Brand: Maytag   Age: 1 - 5 years
Top burners, ignition work fine. Oven dead. I set the oven temp, there's an initial double-click sound, but then no gas sound (usually you hear the gas for 45 seconds, then the igniter lights the gas).
At first I assumed the igniter died and needed replacing. But why no gas at all? So, is it the safety valve?
Not to sound like too much of a dummy but how do I tell if the safety valve was simply tripped and reset it -- or, tell if the safety valve (or even the spark module) is the culprit?
I just want to make sure I order the right part. If it's the safety valve, I imagine the gas would have to be shut off entirely, right?
Ads By Google
Related Models
Maytag MGR4452BDS RANGE- S/C F/S GAS
Maytag MGR4452BDW RANGE- S/C F/S GAS
Maytag MGR4770ADH RANGE- F/S STD GAS
Maytag MGR4770ADL RANGE- F/S STD GAS
Maytag MGR4770ADW RANGE- F/S STD GAS
Maytag MGR5510ADH RANGE- S/C F/S GAS
Maytag MGR5510ADL RANGE- S/C F/S GAS
Maytag MGR5510ADW RANGE- S/C F/S GAS
Maytag MGR5605WB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Maytag MGR5605WW0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Maytag MGR5710ADQ RANGE- S/C F/S GAS
Maytag MGR5710ADW RANGE- S/C F/S GAS
Maytag MGR5720ADH RANGE- S/C F/S GAS
Maytag MGR5720ADL RANGE- S/C F/S GAS
Maytag MGR5720ADT RANGE- S/C F/S GAS
Maytag MGR5720ADW RANGE- S/C F/S GAS
Maytag MGR5720BDQ RANGE- S/C F/S GAS
Maytag MGR5720BDW RANGE- S/C F/S GAS
Maytag MGR5721BDQ RANGE- S/C F/S GAS
Maytag MGR5721BDW RANGE- S/C F/S GAS
Maytag MGR5729ADA RANGE- S/C F/S GAS
Maytag MGR5729ADH RANGE- S/C F/S GAS
Maytag MGR5729ADL RANGE- S/C F/S GAS
Maytag MGR5729ADQ RANGE- S/C F/S GAS
Maytag MGR5729ADT RANGE- S/C F/S GAS
Maytag MGR5729ADW RANGE- S/C F/S GAS
Maytag MGR5730ADA RANGE- S/C F/S GAS
Maytag MGR5730ADH RANGE- S/C F/S GAS
Maytag MGR5730ADQ RANGE- S/C F/S GAS
Maytag MGR5730ADW RANGE- S/C F/S GAS
Maytag MGR5730BDB RANGE- S/C F/S GAS
Maytag MGR5730BDQ RANGE- S/C F/S GAS
Maytag MGR5730BDW RANGE- S/C F/S GAS
Maytag MGR5745ADA RANGE- S/C F/S GAS
Maytag MGR5745ADB RANGE- S/C F/S GAS
Maytag MGR5745ADW RANGE- S/C F/S GAS
Maytag MGR5750ADA RANGE- S/C F/S GAS
Maytag MGR5750ADQ RANGE- S/C F/S GAS
Maytag MGR5750ADW RANGE- S/C F/S GAS
Maytag MGR5750BDB RANGE- S/C F/S GAS
Maytag MGR5750BDQ RANGE- S/C F/S GAS
Maytag MGR5750BDW RANGE- S/C F/S GAS
Maytag MGR5751ADB RANGE- S/C F/S GAS
Maytag MGR5751ADQ RANGE- S/C F/S GAS
Maytag MGR5751ADS RANGE- S/C F/S GAS
Maytag MGR5751ADW RANGE- S/C F/S GAS
Maytag MGR5751BDB RANGE- S/C F/S GAS
Maytag MGR5751BDQ RANGE- S/C F/S GAS
Maytag MGR5751BDS RANGE- S/C F/S GAS
Maytag MGR5751BDS18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGR5751BDW RANGE- S/C F/S GAS
Maytag MGR5752ADB RANGE- S/C F/S GAS
Maytag MGR5752ADQ RANGE- S/C F/S GAS
Maytag MGR5752ADS RANGE- S/C F/S GAS
Maytag MGR5752ADW RANGE- S/C F/S GAS
Maytag MGR5752BDB RANGE- S/C F/S GAS
Maytag MGR5752BDQ RANGE- S/C F/S GAS
Maytag MGR5752BDS RANGE- S/C F/S GAS
Maytag MGR5752BDW RANGE- S/C F/S GAS
Maytag MGR5754QDQ RANGE- S/C F/S GAS
Maytag MGR5754QDS RANGE- S/C F/S GAS
Maytag MGR5754QDW RANGE- S/C F/S GAS
Maytag MGR5755ADB RANGE- S/C F/S GAS
Maytag MGR5755ADQ RANGE- S/C F/S GAS
Maytag MGR5755ADW RANGE- S/C F/S GAS
Maytag MGR5755BDB RANGE- S/C F/S GAS
Maytag MGR5755BDQ RANGE- S/C F/S GAS
Maytag MGR5755BDW RANGE- S/C F/S GAS
Maytag MGR5755QDB RANGE- S/C F/S GAS
Maytag MGR5755QDQ RANGE- S/C F/S GAS
Maytag MGR5755QDS RANGE- S/C F/S GAS
Maytag MGR5755QDW RANGE- S/C F/S GAS
Maytag MGR5765QDB RANGE- S/C F/S GAS
Maytag MGR5765QDB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDQ RANGE- S/C F/S GAS
Maytag MGR5765QDQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDQ2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDS RANGE- S/C F/S GAS
Maytag MGR5765QDS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDW RANGE- S/C F/S GAS
Maytag MGR5765QDW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDW2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5770ADA RANGE- S/C F/S GAS
Maytag MGR5770ADB RANGE- S/C F/S GAS
Maytag MGR5770ADQ RANGE- S/C F/S GAS
Maytag MGR5770ADW RANGE- S/C F/S GAS
Maytag MGR5770BDB RANGE- S/C F/S GAS
Maytag MGR5770BDQ RANGE- S/C F/S GAS
Maytag MGR5770BDW RANGE- S/C F/S GAS
Maytag MGR5775ADB RANGE- S/C F/S GAS
Maytag MGR5775ADQ RANGE- S/C F/S GAS
Maytag MGR5775ADW RANGE- S/C F/S GAS
Maytag MGR5775QDB RANGE- S/C F/S GAS
Maytag MGR5775QDB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5775QDQ RANGE- S/C F/S GAS
Maytag MGR5775QDQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5775QDS RANGE- S/C F/S GAS
Maytag MGR5775QDS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5775QDW RANGE- S/C F/S GAS
Maytag MGR5775QDW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5780BDB RANGE- S/C F/S GAS
Maytag MGR5780BDQ RANGE- S/C F/S GAS
Maytag MGR5780BDS RANGE- S/C F/S GAS
Maytag MGR5780BDW RANGE- S/C F/S GAS
Maytag MGR5870ADA RANGE- S/C F/S GAS
Maytag MGR5870ADB RANGE- S/C F/S GAS
Maytag MGR5870ADQ RANGE- S/C F/S GAS
Maytag MGR5870ADW RANGE- S/C F/S GAS
Maytag MGR5870BDB RANGE- S/C F/S GAS
Maytag MGR5870BDQ RANGE- S/C F/S GAS
Maytag MGR5870BDW RANGE- S/C F/S GAS
Maytag MGR5875QDB RANGE- S/C F/S GAS
Maytag MGR5875QDB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5875QDQ RANGE- S/C F/S GAS
Maytag MGR5875QDQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5875QDS RANGE- S/C F/S GAS
Maytag MGR5875QDS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5875QDW RANGE- S/C F/S GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
igniter, or spark module potential hazard justc30 Oven Repair (including Ranges and Cooktops) 0 02-12-2010 07:26 PM
Replace which part: : igniter, spark module or safety valve? davidinnh Oven Repair (including Ranges and Cooktops) 0 01-06-2010 10:34 AM
Oven safety valve WALJ Oven Repair (including Ranges and Cooktops) 3 12-01-2009 03:19 PM
Spark Igniter Module johnnyjohns Oven Repair (including Ranges and Cooktops) 1 01-02-2009 07:28 PM
Frigidaire Gas Range wont ignite! Spark Module? Tractorshaft Oven Repair (including Ranges and Cooktops) 2 08-20-2008 10:54 AM
