Discuss
Stove doesn't work after self-cleaning mode
 in
I have a whirlpool stove (GR465LXK) that during the self-cleaning mode lost all power to the control module (stove
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Stove doesn't work after self-cleaning mode
  #1 (permalink)
Old 08-21-2007, 06:55 PM
alfrenzel alfrenzel is offline
Junior Member
alfrenzel is on a distinguished road
Default Stove doesn't work after self-cleaning mode
Brand: Whirlpool   Age: 1 - 5 years
I have a whirlpool stove (GR465LXK) that during the self-cleaning mode lost all power to the control module (stove top works but not the oven electronics – I now find out this is a common problem and the self-cleaning mode should not be used).
According to research I've made so far, the thermal fuse is supposedly the culprit. However, I don't think the problem is the thermal fuse since it has both continuity (ohm meter test) and even when bypassed (jumped) nothing happens. What else could the intense heat of the self-cleaning mode have destroyed? Thank you, AL
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-21-2007, 07:06 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
When you say thermal fuse, are you referring to #26 on the diagram below labeled CHASSIS PARTS? There is another fuse inside the control panel. See # 19 on the diagram labeled CONTROL PANEL PARTS below. Let me know...
  #3 (permalink)
Old 08-21-2007, 08:42 PM
Junior Member
Default Stove fuses
Both fuses checked out okay. AL
  #4 (permalink)
Old 08-21-2007, 09:03 PM
Administrator
APP Team
Default
When you were checking the fuse inside the control panel, did you remove at least one of the wires from it? If not, remove one wire and try again.
  #5 (permalink)
Old 08-21-2007, 09:05 PM
Administrator
APP Team
Default
By the way, that fuse is connected to a brown wire between the power board and microcomputer.
  #6 (permalink)
Old 08-22-2007, 04:59 PM
Junior Member
Default
Yes, I checked the fuse (connected to the brown wire) for continuity with one side disconnected and I also jumped it, but no success.
I did notice that the transformer on the power board "may" have overheated. It has a dried dark yellow substance on parts of the exterior, primarily the top and back. Not sure if this is the way it looked when new?
Thanks again for your help, AL
  #7 (permalink)
Old 08-22-2007, 05:07 PM
Administrator
APP Team
Default
This is what it looks like brand new
If you can, see if you get 110 volts to the power board, then see if you get 110 volts to the microcomputer. If you don't feel comfortable working under live voltage, please do not try.
- Wiring diagram for your model
  #8 (permalink)
Old 08-22-2007, 06:11 PM
Junior Member
Default
I'm not sure I checked the correct places, but I have power (115V) at the Blk and W wires at P1 and I have power (115V) at the red and black wires at P8.
  #9 (permalink)
Old 08-27-2007, 03:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi alfrenzel
The power board looks very suspicious to me. If you have 120V across P1-1 and P1-4 terminals (incoming power) and you did not measured a 120V at the P7 plug (across P7-2 terminal and any other terminals), no doubt the problem is the power board (most likely the low voltage transformer).
The part number for the new power board is AP3135669
Good luck.
  #10 (permalink)
Old 12-13-2007, 09:48 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
just curious, i always check to make sure i have proper voltage coming into the unit first .. i find that self-cleaning can cause problems with wires ...however, it is always a good practice to check incoming voltage..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake mode does not maintain set temperature good28 Oven Repair (including Ranges and Cooktops) 13 09-30-2008 12:07 PM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 12:06 PM
oven won't work cherylknudsen Oven Repair (including Ranges and Cooktops) 1 08-11-2007 05:43 PM
Oasis HE - how to open for cleaning? ksevern Washer Repair 1 08-04-2007 10:58 PM
$200 and still don't work Rakar Dishwasher Repair 2 07-27-2007 10:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
