Discuss
Oven does not work after self-cleaning cycle
 in
Used the self-cleaning cycle (I know, big no-no), and now the oven bake and broil elements won't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven does not work after self-cleaning cycle
  #1 (permalink)
Old 03-26-2008, 08:12 AM
Wufpak Wufpak is offline
Junior Member
Wufpak is on a distinguished road
Default Oven does not work after self-cleaning cycle
Model Number: n/a   Brand: Whirlpool   Age: 1 - 5 years
Used the self-cleaning cycle (I know, big no-no), and now the oven bake and broil elements won't work. Meaning the digital display and keypad work, and the cooktop works. I can pretend like I'm going to bake something, set the temp, hit start, and the oven will begin to pre-heat according to the display; however, there is no heating going on inside the oven. I've removed the thermal fuse from the back and it still shows continuity when checked with an ohm meter. A few months ago the same thing happened (this was before we bought the house). We were doing the home inspection, and discovered the oven would not heat. The sellers got it repaired claiming that is just needed a new fuse. I'm assuming it's the same thermal fuse I've pulled and checked that it's good. Any thoughts?
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-26-2008, 04:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide most accurate advise we need the complete model number of the unit.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd sillyshopper Oven Repair (including Ranges and Cooktops) 5 02-14-2008 01:39 PM
After Cleaning Cycle - Oven does not work bokeldol Oven Repair (including Ranges and Cooktops) 5 01-09-2008 07:59 PM
Gas oven will not work after cleaning with Easy Off SB130PER1 Oven Repair (including Ranges and Cooktops) 0 01-04-2008 04:35 PM
Oven door will not open after cleaning cycle cgranstrom Oven Repair (including Ranges and Cooktops) 0 12-29-2007 09:42 AM
Oven will not work after self cleaning Mike Seavey Oven Repair (including Ranges and Cooktops) 0 09-22-2007 07:44 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
