Discuss
Gas Oven won't stay lit
 in
Please help! My gas oven will light only sometimes. It is a Whirpool Super Capacity 465 Model #SF377PEGB7. It's
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Oven won't stay lit
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-25-2008, 09:13 PM
janicet janicet is offline
Junior Member
janicet is on a distinguished road
Default Gas Oven won't stay lit
Model Number: SF377PEGB7   Brand: Whirlpool   Age: 5 - 10 years
Please help! My gas oven will light only sometimes. It is a Whirpool Super Capacity 465 Model #SF377PEGB7. It's 6 years old. If it lights, it usually will bake for a while (maybe 1/2 hour) and then when it tries to ignite again to keep the temp it won't light. After a few failed attempts at lighting (I can hear it clicking as it tries to light) it locks up and quits baking. Very frustrating because it happens randomly, though it seems to be getting worse and more frequent. I can't even use the pre-set time bake option because I can pretty much count on it being off when I get home and the food in the oven still uncooked or half cooked. The cooktop burners work fine. Could it be the oven spark igniter?
Thanks for the help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-26-2008, 03:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
According to the Whirlpool service pointer cause of the intermittent Bake burner operation is improper air flow to the burner.
The correction is to replace the Bake burner with the new modified burner and igniter assembly.
- The part number for the burner & igniter assembly is AP3598752
Here are the break down diagrams for the Whirlpool range Model SF377PEGB7
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-26-2008, 05:36 PM
Junior Member
Default
Thanks so much. I will order the part. Just wondering, how simple is it to replace? I took a look at the part in my oven and it looks like a screw or two hold it in place. Is this something a beginner can tackle or should I call a service tech? Any chance the part comes with instructions?
Thanks again!
  #4 (permalink)
Old 03-26-2008, 08:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the oven floor, the flame spreader and the bottom drawer and you'll see how simple it is.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't stay lit mikevanhal Oven Repair (including Ranges and Cooktops) 1 02-15-2008 12:41 PM
Oven won't stay on kristina Oven Repair (including Ranges and Cooktops) 2 02-04-2008 11:07 AM
Oven will not stay lit bradk36 Oven Repair (including Ranges and Cooktops) 1 01-15-2008 06:33 PM
Oven won't stay lit donnalee115 Oven Repair (including Ranges and Cooktops) 3 11-27-2007 03:27 PM
Oven doesn't stay heated gap118 Oven Repair (including Ranges and Cooktops) 0 11-21-2007 05:10 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
