Oven works sporadically.Shuts off by itself.after opening oven door does not turn back on.sometimes does,sometimes not.Burners work.Broiler works.Any suggestions?
When the oven shuts off the digital display stays on.The door does not trigger it.I just find that when I open the door at times even though the display may read "350" the oven is not functioning at 350. It just goes off for no reason.the door does not cause it to go off.
Very likely the problem is a bad Bake relay on the control board. Possible it can be resoldered or replaced. Otherwise the control board has to be replaced. - The control board Part number: AP2995125
