Discuss
whirlpool double oven control panel DEAD!
 in
I had both ovens going the other day. After ending the bake cycles, the panel just went dead! Black! If
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » whirlpool double oven control panel DEAD!
  #1 (permalink)
Old 01-01-2010, 08:49 AM
Junior Member
dozija is on a distinguished road
Default whirlpool double oven control panel DEAD!
Model Number: RBD306PDT14   Brand: Whirlpool   Age: 1 - 5 years
I had both ovens going the other day. After ending the bake cycles, the panel just went dead! Black! If I open the oven doors, the lights turn on. If I push the start button I get a dit daaaa dit dit dit sound. But other than that, no action. I turned off the breaker box to try to "reboot" it, but no go. Nothing. I hope there is something easy to fix that I am overlooking. I've never had problems with my ovens before! Thanks in advance for any help.
Ads By Google
Related Models
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
Amana RBK26AA Range - S/i Std Gas
Amana RBK26AA0 Range - S/i Std Gas
Amana RBK26AA093M Range - S/i Std Gas
Amana RBK26AA5 Range - S/i Std Gas
Amana RBK26AAL Range - S/c S/i Ddraft Gas
Amana RBK26AAW Range - S/c S/i Ddraft Gas
Amana RBK26CBL Range - S/c S/i Ddraft Gas
Amana RBK26CBW Range - S/c S/i Ddraft Gas
Amana RBK28FG Range - S/i Std Gas
Amana RBK28FG0 Range - S/i Std Gas
Amana RBK28FG5 Range - F/s Std Gas
Maytag RBK28FG5  Range - F/s Std Gas
Amana RBK28FGL Range - S/c S/i Ddraft Gas
Amana RBK28FGW Range - S/c S/i Ddraft Gas
Amana RBK29AA093M Range - S/i Std Gas
Amana RBK29AAL Range - S/c S/i Ddraft Gas
Amana RBK29AAW Range - S/c S/i Ddraft Gas
Amana RBL22AAL Range - S/c S/i Ddraft Gas
Amana RBL22AAW Range - S/c S/i Ddraft Gas
Amana RBL26AAL Range - S/c S/i Ddraft Gas
Amana RBL26AAW Range - S/c S/i Ddraft Gas
Amana RBL39AA0,5 Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 01-03-2010, 06:48 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens | AppliancePartsPros.com
Here is the tech sheet
And a manual
https://secured.whirlpool.com/Servic...LE/8178007.pdf
Could be the control board transformer thermal fuse is blown, see page 3-2 in the manual.
Unplug the unit and check it with a meter.
If OK
Check the transformer windings
Note that is always safer to try and find the fault with the power off as 240 volts is lethal.
If OK
Check that the transformer is getting power should be 120 volts on the primary. Check that the voltage suppressor is OK.
Check that the transformers secondary is putting out voltage, I beleive it is 24 volts AC.
__________________
  #3 (permalink)
Old 07-13-2011, 10:04 AM
Junior Member
ms.nita is on a distinguished road
Default Whirlpool double oven control panel
My oven has the very same problem. I was told the control panel needs to be replaced, but that part is not available and on back order! I'm thinking that is a widespread problem. My oven is about 7 years old.
  #4 (permalink)
Old 07-14-2011, 03:44 PM
Junior Member
Default
Quote:
Just found out from whirlpool today, they no longer make the part I need! Now I need a new oven....it won't be a whirlpool!
  #5 (permalink)
Old 10-17-2012, 02:40 PM
Junior Member
Rafasan is on a distinguished road
Default Double Oven Control Panel Replaced for second time
I have the Whirlpool Double Oven and the control panel went out after 4 or 5 years. It has now gone out again. And it's not cheap!! Can't believe it. Must a design flaw in this model cause others have reported the same thing.
  #6 (permalink)
Old 10-18-2012, 12:05 AM
Senior Expert
APP Volunteer
Default
Rafasan
Are you sure it is the control board or has it blown the thermal fuse that kills power to the board?
__________________
  #7 (permalink)
Old 10-18-2012, 07:52 AM
Junior Member
Default
yes, I checked the fuse and it's fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Oven Dead natebee Oven Repair (including Ranges and Cooktops) 33 10-04-2010 03:14 AM
Whirlpool Double Oven Dead After Self Clean cats8fish Oven Repair (including Ranges and Cooktops) 2 12-13-2009 03:25 PM
Whirlpool Double Range Control Panel Problem Title Man Oven Repair (including Ranges and Cooktops) 2 10-05-2009 09:14 AM
Double Oven control Panel nansells Oven Repair (including Ranges and Cooktops) 2 05-25-2009 04:41 PM
Whirlpool Stove-Control Panel Dead?? danmcnally Oven Repair (including Ranges and Cooktops) 3 12-16-2008 07:36 AM
