Discuss
Oven to long to heat up
 in
The oven has a new element and sensor. It takes 45minutes to heat up to 350. What else is a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven to long to heat up
  #1 (permalink)
Old 03-24-2008, 05:58 PM
Alan K Alan K is offline
Junior Member
Alan K is on a distinguished road
Question Oven to long to heat up
Model Number: KEDC205YBL   Brand: Kitchen Aid   Age: 5 - 10 years
It takes 45minutes to heat up to 350. What else is a probable cause ?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-25-2008, 02:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Alan,
Did the Bake heat element get red?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-25-2008, 03:05 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Alan,
No it never went red at all. 45 mins to get to 350 seems to long for me so I changed the element and sensor. no luck it did the same.
  #4 (permalink)
Old 03-26-2008, 02:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Allan.
Most likely the problem is a bad electronic control board, but before you replace it I would recommend to perform the troubleshooting as described in the tech sheets (page 2).
- The part number for the control board is AP3025959
Here are the break down diagrams for the Kitchen Aid range Model KEDC205YBL0
__________________
  #5 (permalink)
Old 03-26-2008, 04:46 PM
Junior Member
Default
Thank-you for the info my friend.
Alan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How long does oven gas valve opens when the pilot already extends? herbolaryo Oven Repair (including Ranges and Cooktops) 0 02-13-2008 12:19 PM
Takes tpo long to dry.. SLEEPING_GIANTRT Dryer Repair 3 12-23-2007 01:25 PM
Electric oven takes a long time to heat kuroda01 Oven Repair (including Ranges and Cooktops) 0 11-04-2007 08:24 AM
oven too long to pre heat tellez.a Oven Repair (including Ranges and Cooktops) 3 10-12-2007 07:34 PM
oven takes long time to cook Wmurky Oven Repair (including Ranges and Cooktops) 2 07-29-2007 01:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
